Old 1/26/07, 9:45 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 3 tab shingles curling
First pic shows the shingles in the front of the house ( facing east )
Shingles are laying down pretty flat.
Second pic shows the shingles from the rear of the house ( facing west )
Notice all the curling of the outside edges.
Most of the shingles facing east looked good.
Most of the shingles facing west look considerably curled.
Attic looks good throughout. 2 gable and 2 turbine vents.
Shingles appear quite new...very little granular loss.
Could the issue be hot afternoon sun on west side???
Old 1/26/07, 10:03 PM
wsiegel wsiegel is offline
Default Re: 3 tab shingles curling
Could be one of two things. One of them you are right about. The sun will kill these shingles after a few years. My gues is that this roof would be about 10-12 years old.
The other possibility is defective shingles. If the roof is newer this may be the case. It is possible that there were two different lots of shingles used on the home. However, I am betting on the sun.
Old 1/26/07, 11:14 PM
dchew dchew is offline
The west and south sides of the house will always get much more sun exposure than the other two.
I've seen houses that had new roofs installed in cooler temperatures and in the hot summer, the shingles started to have problems with temperature expansion. Putting on a new roof isn't as easy as it sounds.
Old 1/27/07, 6:37 AM
Barry Adair's Avatar
A large percentage of these that I see are due to inadequate ventilation.
Venting installed to the code minimum does not necessarily make it right.
General info: http://www.owenscorning.com/around/r...leshooting.asp
Cold temperature/Canadian info: http://www.iko.com/misc/CasmaPdf/07-CurlingInWinter.PDF
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/28/07, 1:52 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Chris;
What part of the world is this property located? Is it in a high wind area?
Old 1/28/07, 3:03 PM
near st. louis, illinois side of the river
high wind area, no
Old 1/29/07, 2:08 PM
edavis1 edavis1 is offline
I have seen this happen on new roofs when the shingles were installed in very cold temps.often times when summer sun and heat gets to them they will go ahead and lay down. We have also seen defective shigles do this and they will break off easy,and catch in the wind ect.Sometimes old bundles of shigles will be mixed into the new bundles when deliverd.We always check before unloading.One bad bundle can cause terrible grief for the roofer and the homewowner.
EDavis
PObox173
Taneyville,Missouri 65759
NACHI06092670
Old 1/29/07, 2:52 PM
sfigert sfigert is offline
Noticed the curling was near a dormer I'd check the ventilation too.
Old 1/29/07, 5:25 PM
dfogleman dfogleman is offline
Check out www.airvent.com, you will find formulas to determine what the necessary ventilation would be for this home. I am concerned about your statement that there are 2 turbines and 2 gable end vents, this is not a very balanced system and is prone to short circuiting. I too am curious about the dormer, is the space the dormer serves a finished space or open attic? If it is finished then I ask how is the attic ventilation system you detailed supposed to serve the area. If it is unfinished then you likely have a dead air problem, the air is entering the gable end vent and going straight out the nearest turbine.
The ideal attic/roof ventilation system will wash the underside of the roof from eave to peak with cool air, just as rain water flows the opposite direction on the top side of the roof.
Look at air as a lazy entity, it seeks the easiest path to get back out of the attic once it comes into the attic through its inlet area. However the air that is just sitting around in places here and there is likely to continue to do so.
Be wary of obstructions that may be in the attics that can block the flow of air in an attic. I have experienced situations where the boxes of 'sh..tuff' was piled so high the attic could not vent correctly.
Look closely too at the flashing at the bottom corner of the dormer, I would have fired an employee that installed this way. The method used allows for a direct entry point for water providing that there is not any other flashing that is out of site under the shingles (I doubt that there is), this is a common mistake made by people that install roofing and siding and the reason for most of the leaks I repair at the corners of dormers and chimneys.
Is inadequate roof or attic ventilation a defect? gliebig Exterior Inspections 85 1/16/08 6:56 PM
Comp shingles over wood shingles Matthew Hopkins Exterior Inspections 28 10/16/07 11:19 AM
Roof Shingles tpriddy Exterior Inspections 6 2/11/06 3:13 PM
