![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() CLIMATE: Enclosure Advances Address Severe Weather By C.C. Sullivan Mark Twain remarked in 1897 that “while everyone talked about the weather, nobody seemed to do anything about it.” Things have changed. Ever since the 2005 season – which brought the United States more than twice as many named storms and hurricanes as in an average season, according to NOAA’s Climate Prediction Center – building professionals, product manufacturers, and codes officials have worked to produce tougher buildings. New techniques and regulations introduced since the year of Katrina make buildings better at resisting projectile impact, wind-driven rain and high pressure differentials. This has been driven in part to protect human lives, as well as to stem financial losses. According to the National Association of Home Builders (NAHB), Washington, D.C., seven of the 10 most costly natural disasters in the United States have occurred since August of 2004. Insurance companies have paid out a staggering $40.6 billion in claims in six different states due to Hurricanes Katrina and Rita alone. Experts such as Dr. Robert Hartwig... more... ![]() ![]() More hurricanes and severe weather are the trend, according to scientists at NOAA and elsewhere. In this visible spectra satellite image, the extent of Hurricane Hugo is seen on September 21, 1989. (Courtesy the National Hurricane Center/NOAA.) CODESAiring Out: More Codes Call for Air Barriers By PROTECT Staff Have you specified any air barriers lately? If not, chances are you will soon. Recognizing the role that air barriers play in increasing energy efficiency in buildings, more codes are now including building envelope provisions. New rules concerning air barriers have taken effect in a growing number of municipalities and in states like Massachusetts, Wisconsin ![]() ![]() StoGuard Waterproofing/Air Barrier with Sto Gold Coat, “Steel Frame with Brick Veneer” Detail No. 20.00dG, 2007. SOURCE: Sto Corp. and Michigan. The International Energy Conservation Code (IECC) also calls for air barriers, and several federal agencies now require them. Up to 40% of energy used to heat and cool buildings, says the Department of Energy, results from uncontrolled air leakage. Air barriers can conserve energy by 30% to 40% in heating climates, and 10% to 20% in cooling climates... more... ![]() ![]() ENCLOSURE DESIGN: Ways to Win: Condensation Design Strategies For more reliable envelope designs use an integrated approach. This includes: 1. Control Driving Forces. Reduce the forces that drive water vapor through the envelope. High humidity levels in the ambient air should be reduced through dehumidifi cation and/or mechanical ventilation. Mechanical systems should provide complementary pressure control to minimize condensation potential. 2. Select Durable Materials. Building envelope materials located at potential condensation planes should not be... more... ![]()
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 7/11/08 at 6:13 PM.. |
Thanks! Barry.
Great Info. Detail's Detail's "I create controversy whether they like it or not" |
Hey, Carl;
Add this to your library of info, it will come in handy when you start your consultation Bussiness for the Proper installation of Stucco. Hint LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel,
That means I would have to wage WAR with the fine folk's at ASTM and AAMA! Window installation and flashing detail's cause more damage than stucco even if it is not installed to ASTM spec's! IMO of course To many FAUX product's on the market! And FAUX spec's by material mfgrs. Then their is the FAUX labor pool. And the FAUX inspection's by city code's inspectors. IMO of course! I need to stop now my vision is blurred. "I create controversy whether they like it or not" |
Well, maybe it is time for a bunch of us to colaborate and address the Faux's
and make it correcteaux.! What a debate that would make Eh! LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
1. Sill pans that exit the water to the exterior of all claddings!
2. http://dryflekt.com/ On all claddings! 3. Windows with trim around them flashed in 3 places to the outside of the trim not just the window width. 4. No taping of horizontal joint's of moisture barrier's! Just for starters! "I create controversy whether they like it or not" |
That is a good start, now maybe we can just keep adding to it.
Might not be pretty! "I create controversy whether they like it or not" |
How can a window be called self flashing?
When it has no end dams? Yet they call for end dams on flashing's. "I create controversy whether they like it or not" |
I never seen a self-flashing window, yet.
Carl, check this out and let me know if you agree with this procedure. http://www.hgtvpro.com/hpro/pac_ctnt...&videoid=66905 Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
No !!!
Well, that was short and sweet.
So which way is your preference? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I gotta leave for a while when I get back
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi. Rick, hope you doing well.
I think Carl is out and about pondering and mulling this faux problem over. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
