![]() 1 - Reasons for this icicle development? 2 - Are they in your home inspection report? 3 - Your narrative. (optional) |
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Poor ventilation and poor insulation, This is a red flag to all inspectors that pull up to a home that looks like the photo. And icicles of that size or any size are danderous !!
John Zirzow Homestead Inspections llc Eagle River, WI 54521 715-479-4151 |
That is very common in SSM Ontario on the south side. Homes with icicles are always a result of lost heat into the attic space with no adequate insulation and poor ventilation, So I too agree with John Z
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Something is amiss with your reasoning. |
Living in the WRONG part of the country!! Ef that noise
.......................................... ...........................................Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Heat from the sun elevates the big icicles developing. there are still some on the North from heat loss but not 6 feet long. Unless the house is extreme in lacking insulation then yes the icicles can be as long as 6 feet on the North side.
Not only poor ventilation causes icicles.
Block, dirty out of slope gutters, downspouts can case this symptom. Narrative is system related Ben. Attics structure differ. ROOF STYLES. Narrative in INSULATION section of my report. Safety issue. Icicles send Canadians to the hospital every year. Some through ladder related accidents from cleaning the icicles , others from having the projectiles fall on them. http://www.cbc.ca/news/canada/montre...2.html?ref=rss DEFICIENCY: INSULATION Insufficient AMOUNT OR R VALUE ( R-restriction ) insulation in A VENTED attic space. DEFICIENCY: VENTILATION; Insufficient baffle or chute ventilation and deck exhaust venting. One baffle or chute vent is required for each roof deck truss or rafter spacing, per soffit space. RECOMMEND: A.) INTAKE; Soffit venting baffles between each ( rafter or truss soffit ) space for increased air flow. B.) EXHAUST: One roof deck vent for every 300 SQ.FT. of attic space. To exhaust the attic's interior RH and temperature. To condition the air to be equal to or close to the outside temperature and RH condition. RECOMMEND: maximum required code. R32- to R40 of insulation for ventilated attic spaces. This well reduce your energy bills and maintenance-cost of your home. IRC CODE for unventilated roofing system. LINKS TO ROOF AND ATTIC VENTILATION. https://docs.google.com/viewer?a=v&q...GOrK1I0g&pli=1 2009 IRC, Section R806.4; 2012 IRC, Section R806.5, Unvented attic assemblies I would like feed back please. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Didn't we have this conversation last year?
Yep... thought so... http://www.nachi.org/forum/f16/ice-d...layment-51946/ Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
It was in the low 40's here yesterday and I had shorts on and my brother-in-law from San Diego was all bundled up including gloves....wish I had a pic of that to share, but you are right, maybe some day I will live where I can golf year round.
even if you have 2 foot of insulation in the attic, if you have leaks in the vapor barrier or some exaust fan that exiting on the attic you will get ice damming
soon as you get snow on the roof, this snow act as insulation and start to melt under, that produce water who is running under the snow, soon as it get at the suffit area (where the coldest part of the roof is) the water freeze and ice damming start 7 year ago i start to build a house in september, once the vapor barrier was install, i have apply 4 inch of insulation in the attic, i had no ventillation because i have installed a big tarp at the suffit area to prevent snow going in the attic i had heat the house all winter long (we where working in it) and i never had any icicles on the roof also ,on the sun set side the icicles are always bigger, this is cause by the sun radiation heat Guy Bosse/ Inspector Member of interNACHI & IAC2 Last edited by gbosse; 12/27/11 at 1:56 PM.. |
The truth. So...don't eat icycles.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 12/27/11 at 2:06 PM.. |
every day i go on that forum i learn something new!
THIS IS THE BEST ONE I EVER SEEN Guy Bosse/ Inspector Member of interNACHI & IAC2 |
Hows this for ice dams!!!!!
Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com |
What astounds me Mr. Russel is the lack of energy and investigation to solve the obvious deficiency problem.
PS: That example looks like Niagara Falls after a long freeze. What I here. Well every one has icicles, every home has foundation cracks. These are introduced through the seller, agents and neighbors in my opinion only and the public must be made aware of the damage and safety concerns.. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| I need a 20,000+ square foot building inspected in Orlando. Anyone want it? | gromicko | Florida Inspectors | 4 | 2/24/11 2:01 PM |
| How smart is your right foot? | ldapkus | Miscellaneous Discussion for Inspectors | 14 | 12/7/07 6:35 PM |
| 6 foot clearance for counduit?? | gbrasseur | Electrical Inspections | 4 | 3/2/07 9:25 PM |
