| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
Can anyone tell me what or what may have caused these spots on the brick on this home? It appears to be only on the darker brick, that also looks like it may have some sort of glaze on it.(the lighter red brick doesn't have a glazed look to it) House was built in 1954. The spots seem to be located or coming from in small holes in the brick. It is extremely hard stuff, couldn't scrape it off with a knife blade! It appears to have been there for many years. Some areas have turned black. I told the woman I thought that it was probably something from when the brick was fired. Just a guess. There doesn't appear to be anything structurally wrong with the brick itself. She was curious and now so am I. Any ideas?
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
tallen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Richard,
They look OK from here You may want to contact or pass this on to your client BIA for further info badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
imperfections during the original firing.
1) paint it 2) replace it 3) cover it 4) leave it alone I vote four |
Typical impurities found in brick. It accounts for the many colors and speckles seen from the firing process and oxidation that takes place afterwards.
Once had a client insist the workmen were smashing their cigarettes out on her new bricks. She was a "head" doctor and was about as anal as anyone Ive ever met. Took a lot of convincing her to accept this was normal appearance for bricks. Check out this website; http://www.claybrick.org.za/publicat...ical_Guide.pdf http://www.bia.org/html/frmset_thnt.htm Last edited by dedwards; 1/14/08 at 11:25 AM.. |
Hi. Richard;
The brick pictures you posted to me are only showing impurities that were in the clay used to manufacture this brick. Some of those impurities will absorb more heat than the clay and produce this affect when firing. Below is a little more information that might help some understand the process. PROPERTIES "All properties of brick are affected by composition of the raw materials and the manufacturing processes. It is for this reason that most manufacturers blend clays to reduce the possibility of impurities from one clay source affecting the overall quality of the finished product. Similarly, the standardization of the manufacturing processes permits the manufacturer to limit variations due to processing and to produce a more uniform product. Product Use The properties that most concern the users of brick are 1) durability, 2) color, 3) texture, 4) size variation, 5) compressive strength and 6) absorption." http://www.bia.org/BIA/technotes/t9.htm "Common clay is clay or a claylike material that is easily molded or shaped and changed into a glasslike material at temperatures of 1,100 °C (about 2000 °F) or less. The minerals found in common clay are biotite, illite, muscovite, and sericite; other minerals, such as kaolinite, smectite-group clays (montmorillonite, saponite, nontronite, and so forth), mixed-layer clays, and chlorite, also are present in many deposits. Common clay is usually higher in alkalies, alkaline earths, and iron-rich minerals and lower in aluminum than ball clay, fire clay, and kaolin. Common clay is mined in hundreds of places across the United States. When common clay is processed, it is used mainly in the manufacture of building bricks." Brick Clay: suitable clay for the manufacturing of bricks or coarse pottery. Often an impure clay containing iron, calcium, magnesium and other ingredients is referred to as brick clay. The chief chemical composition of brick clays is silica, alumina, iron oxide, magnesia, lime and alkalis. Either more or less than the required amount of any of these constituents may cause serious damage to the products. The presence of some harmful constituents like iron concretions, stone particles, soluble salts and limestone has a detrimental effect on brick." http://banglapedia.search.com.bd/HT/B_0626.htm "All properties of brick are affected by composition of the raw materials and the manufacturing processes. It is for this reason that most manufacturers blend clays to reduce the possibility of impurities from one clay source affecting the overall quality of the finished product. Similarly, the standardization of the manufacturing processes permits the manufacturer to limit variations due to processing and to produce a more uniform product. http://www.mii.org/Minerals/photoclay.html http://www.state.ar.us/agc/clay.htm Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
Was there any evidence of vine growth. Just going out on a limb.
Guys, thanks for all of your responses! That is pretty much what I told her(that it was most likely something that occured in the firing process). I will pass along the info you have all sent. It's nice to know I can always count on my NACHI brothers to come through with great information. Thanks again, Rick
Mark, no there was no evidence of any vine or foliage on the home. Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service Last edited by rslocum; 1/14/08 at 11:44 PM.. |
Thanks Bary!
Looks like vine damage to me. |
