Old 11/22/08, 5:10 PM
Al D. Bolt Al D. Bolt is offline
Default Acceptable?
This roof is coming up on its first winter. Any comments about how these areas were handled?
ID:	25370   acceptable-img_2200-small-.jpg.jpg
ID:	25372   acceptable-img_2208-small-.jpg.jpg
ID:	25373   acceptable-img_2223-small-.jpg.jpg
ID:	25374   acceptable-img_2227-small-.jpg.jpg
Old 11/22/08, 5:41 PM
Marc D. Shunk's Avatar
Banned
Default Re: Acceptable?
Looks like they've made some excellent funnels to shove water under some of the shakes.
Old 11/22/08, 6:17 PM
My client says the roofer told them that the staples for attaching shingles over the membrane in the areas without shingles would cause leaks in the membrane. He told them this is an acceptable practice. There are also some flashing issues which should be corrected.
Another roofer tells my client that that the whole roof needs to be replaced saying it won't last the snowy winter.
Old 11/22/08, 7:48 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
First pic is real questionable. Not sure about the others. Just not enough detail for me to tell.
Old 11/22/08, 7:53 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
See this
http://www.cedarbureau.org/installat...manual-p10.pdf
for the whole thing
http://www.cedarbureau.org/installation/roof-manual.htm
Old 11/22/08, 7:57 PM
James F. McKee's Avatar
In the first picture why would the flashing go under the membrane????.....warning....Danger Will Robinson....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/22/08, 8:00 PM
Are you saying I wasn't seeing things???
Old 11/22/08, 8:02 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good catch
You should win some sort of prize.
Old 11/22/08, 8:03 PM
that's the way it looks to Me frank...bass akwards is my guess...
Jim Mckee
Amherst, Ohio
Old 11/22/08, 8:16 PM
OK Another question. On the back and sides of the chimney. Is the membrane cut flush with the chimney where it penetrates the roof??????
Old 11/22/08, 8:27 PM
sorry can't help you with that one from that picture Frank...
Jim Mckee
Amherst, Ohio
Old 11/22/08, 8:47 PM
On the back and sides of the chimney it is uncertain where the membrane ends. The finish masonry was applied over the membrane.
On another chimney the finish masonry was applied over the shakes. See photo #2159.
Back to the exposed membrane on steep slopes without shakes. Is there an acceptable argument for not putting shakes on the areas with adequate slope? Is there a more acceptable procedure over the areas with less slope? See photos in original post.
Some of the exposed areas are visible from the ground. See photos #2338, 2387.
ID:	25391   acceptable-img_2338-small-.jpg.jpg
ID:	25396   acceptable-img_2387-small-.jpg.jpg
Old 11/22/08, 9:49 PM
"Back to the exposed membrane on steep slopes without shakes. Is there an acceptable argument for not putting shakes on the areas with adequate slope? Is there a more acceptable procedure over the areas with less slope? See photos in original post." The membrane was used to open up some areas that shakes would have interferred with the water flow. The lowest points of those areas don't appear to be open enough. Personally, I would have preferred 20 oz. copper, or lead coated copper, flat-locked and sweated together. Not totally familiar with SBS and APP membranes, but only consider them to have a 10 year life. Shakes are 'supposed' to last 40 years. Doesn't make sense.
As for the other chimney. Where is the water to exit at eave? Looks like it drains into/behind the stone veneer.
Old 11/22/08, 10:46 PM
Carl A. Brown's Avatar
Lack of kickout diverter.
Old 11/23/08, 1:57 PM
On the other chimney, since the finish masonry was set above the shakes, kick-outs were formed with the mortar.
Some kick-outs were absent at other areas.
What is an acceptable differental tmp gporter Inspecting HVAC Systems 60 9/29/07 8:22 PM
Acceptable roof rafter repairs ldapkus Exterior Inspections 14 7/17/06 12:49 PM
Acceptable truss? dbucknavich Structural Inspections 21 5/24/06 6:34 PM
acceptable? jweinberg Electrical Inspections 24 3/2/06 10:45 AM
