Old 9/21/06, 10:45 PM
nbhi's Avatar
nbhi nbhi is offline
Default Access Hole
Would any of you even attempt to go thru this 16x13 access hole for a crawl space? What is the minimum size? How would you word it that you did not access the crawl space.
Regards
Gary
Attachment 5686
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 9/21/06, 10:47 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Default Re: Access Hole
Sure I would and have, but it would also depend on what I saw on the other side of it while just looking thru.
If I can't fit my big butt thru, that's what I tell them. I also tell em, make it bigger and I'll try again for a reinspection fee.
What you tell them depends on why YOU chose not to go into the crawl space. No big fancy words needed, just tell them why along with what you could miss by not getting in there and offer to come back if the access is made bigger.
Sometimes it just ain't worth it!!
Old 9/21/06, 10:50 PM
Peter Doane's Avatar
Regards
Gary
Attachment 5686
Minimum access opening is 18 inches by 24 inches.
Minimum access opening if mechanical equipment (i.e. if an HVAC system is located in the crawlspace) is 30 inches by 30 inches.
Minimum clearance between the soil and joists is 18 inches and 12 inches between the soil and beams.
Minimum ventilation, every 150 square feet of floor space, requires a one square foot ventilation opening.
Access to the crawl space is smaller then standards. We recommend the crawl space access be dug out to allow reasonable and safe entrance. ** Think safety,.. if you have to get out in a hurry,.. do you think you could?? Read the thread below: How fast can you crawl?? HA!
http://www.nachi.org/forum/showthrea...ht=crawl+space
Peter Doane
NACHI ID# 05120681
Old 9/21/06, 11:12 PM
nbhi's Avatar
Guys
I could not get in there without putting alot of effort in to it, so I chose not to go. I feel as though I am not doing what my client hired us to do. Any thoughts
Old 9/21/06, 11:25 PM
Brian E. Kelly's Avatar
Regards
Gary
Attachment 5686
My head is 13" by 16" Gary, so no I would not go in there.
Old 9/22/06, 12:32 AM
Dennis DiVito Dennis DiVito is offline
It states in my agreement that I will not enter access openings less than 18x24 or if I deem it unsafe for me to enter. Conditions such as standing water with electrical cables hanging down, not enough clearance between ground and framing or mechanical system obstacles.
So they already know I won't go into areas with deficient access. I am doing what they agreed for me to do. Remember, the inspection covers visible and readily accessible areas.
Old 9/22/06, 1:07 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Nothing stopping us from using a flashlight or digital camera and reporting what we see or don't see!!
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 9/22/06, 1:33 AM
Joe Funderburk, CMI's Avatar
I don't think I would have attempted it unless the CS was much larger on the inside.
My state's SOP says: "The Inspector is not required to:
1) Enter crawl space with headroom less than 18 inches or where adverse conditions exist."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/22/06, 2:36 AM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I hope you noted there was a big chunk out of their foundation, cause that is what that is. Doesn't appear to be an access port, just a busted out piece of a raised foundation.
I'd also mention the foundation doesn't seem to have any steel in it. Or did they just cut that out when they busted through?
Old 9/22/06, 11:39 AM
If you put a wood frame around the opening and attached a wood door, it would look like most access openings I see. Seems like an old house that has stood the test of time. I'd hesitate to recommend a metal lintel.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/22/06, 12:26 PM
mcraig mcraig is offline
Please Note: mcraig is a non-member guest and is in no way affiliated with InterNACHI or its members.
Look for my past thread on crawlspaces.
Also depending on the year of the house you might find that there is an access hatch in the floor of one of the bedroom closets ( most of the homes that have the small vents outside do have an access hatch in the house) you might have to look for it. I have found that people have carpeted or put some form of floor covering over them in the past then people forget there even there. I have found them in bathroom walls and kitchens to. Most people have forgot where they are but I will bet dollars to doughnuts there is one in 98% of all homes.
Old 9/22/06, 6:34 PM
I am not a big man, and would still call this inaccessible.
Call me later when I can access it.
Crawl space was not Inspected due to inaccessibility.
Marcel
</IMG></IMG>
Old 9/22/06, 7:03 PM
dhelm's Avatar
dhelm dhelm is offline
I think I'd tell them that my midget just quit.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 9/22/06, 10:19 PM
Here is what it looks like from the inside of one of those little crawlspaces looking out one of those little vent openings.
Old 9/22/06, 10:29 PM
Attachment 5722
If that's electric wiring on the ground, I'm definitely NOT going in there.
I usually am able to lay on the ground and point my camera in there. It's amazing what I can see---and disclaim the rest until there's a larger access installed.
Frree online access to Field Training Manual from PHII. gromicko Special Discounts for InterNACHI Inspectors 3 8/25/07 7:49 AM
Question for house inspector (posted by Kim Chan) AskNACHI.org AskNACHI.org Inspection Questions Forum 18 6/17/07 12:56 PM
Access To RoofNav Nalliah Thayabharan Commercial Inspections 1 3/23/07 9:16 AM
