Old 2/7/10, 5:55 AM
John Evans John Evans is offline
Default Another Deck Issue
Home constructed 1984 with cantilevered deck joists. All of the adjoining townhomes have or had the same deck design, original deck extended about 10' beyond rear wall with no vertical supports. Many of the decks have been replaced, including the one I inspected. The deck contractor cut the cantilevered joists flush at the rear brick veneer wall and lag screwed the new ledger board to the cut off original joist ends. To make matters worse, the original joists are not pressure treated.
I called the local permit office, no permits pulled for new deck, county would not allow this deck to house connection.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 2/7/10, 8:40 AM
David P. Valley's Avatar
Default Re: Another Deck Issue
Beautiful work...
Using the Prescriptive Residential Deck Construction Guide mcyr Exterior Inspections 0 7/21/09 8:10 PM
Check The Deck wdevries Canadian Inspectors 1 7/9/08 3:00 PM
Another deck Collapse rcooke Canadian Inspectors 11 3/30/08 9:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 3:05 PM
