Any way these rail guards are able to support 50lbs? The two stringers are 1x4's with a 1x1 blocking in the center. This was done to the top and bottom stringers. You can see with one of the photos, I was able to push it out when the blocking was actually missing. I am going to put it in the report, but was curious if this is acceptable as a standard.
Also, anybody know what the longest span of a 4x12 is? Thanks in advance. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Last edited by jwicklander; 7/23/10 at 10:39 PM.. Reason: changed 200lbs to 50lbs |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Jeff , do you have any pictures of the underside to show joists ?
Trying to figure if that is a cantilevered or if you have a ledger. Not sure of the rim joist on a span chart off hand . I swear it looks as if I see a downspout going through one of the supports underneath. |
Jeff,
I don't have time right now, but will check back later tonight. Check here for answers to your questions... http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Hey Jeff....
I was looking at the Deck Construction Guide before I posted and I saw the example that they had for the guard rails. Since this was an example, I was just wondering if anyone else had seen the setup that I encountered for the rails involving the blocks. The 4x12 span chart only noted down to a joist length of 6ft, where the joist length I saw was at 5ft. I'm still thinking that a 20ft span is too much. Thanks for your input. Bob... Yeah, that is a ledger that's run along the building - including where the cantilever is. It's going to be noted. Thing is... if everything was passed by Mr AHJ, there's a whole subdivision of these 2nd level decks that have been installed incorrectly. I gotta look out for my younger client, who will most likely have a group of friends over for her moving in party out on that deck. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Jeff,
I think you will find this interesting reading. http://forums.jlconline.com/forums/s...ad.php?t=53062 Although the thread was started for a different question/reason, there is a lot of info relavent to your situation. Hope it helps. PS... looking at other span charts, depending on species and load, the max. I see for the beam is 7ft. And no, I have never seen the guardrail set-up you have. I would suppose it would be okay if the upper and lower rails were attached to the posts with hardware/brackets, not just toenailed, which as you can see, doesn't work. Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeff...
Thanks again for the input. Quit giving me these links to read up on...I have to finish my report! Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Wish I could help more but it does not seem to be a true cantilever with those side supports.
Would like to find some info on that style but had no luck when searching. I am also curious just how much support they are giving and what is on the other side of the garage. Sure would be nice to see blueprints on something like that. |
Trying to help you search right now and there is lots on Guardrail post to rim joist connections but not much on handrail to guardrail post connections other than the obvious 200 lb pull requirement.
Sure looks bad with those nails going into the block like that. Seems to me they would split the wood. |
Considering some of the porches I see in the city i would not depend on the AHJ to have caught anything.
I suppose it looks strong enough but wish I could find an example somewhere. Normally they would toenail it in from both sides of a single rail of course. |
As it pertains to the span of lumber it does depend upon the species of lumber, grade and the demension on center to the next joist. Look on the side of the lumber for any infor., it is proberly worn off.
You have identfied a major safety concern, as always u know to inform customer to call in ???? God keep us safe Bill Bill Stenger master electrician/licensed elec inspector (oh,KY) certi. bldg inspector (I.C.C.) |
Judging from the picture that looks to be fairly new construction and if that is the case the designer of record would have to have approved the gaurd rail design. Even though I'm surprised a designer would just use toe nails. I would say the problem is more of a workmanship issue. The basic code articles require that (1)the top of the railing be no less than 42" above the deck (2) handrail and assemblies and gaurds shall be able to resist a single concentrated load of 200 lbs. applied in any direction at any point along the top, and have attachment devices and supporting structure to transfer this load to appropriate structural elements of the building (3) intermediate rails, balusters, and panel fillers shall be designed to withstand a horizontally applied normal load of 50 lbs on an area equal to 1 square foot (4) open gaurds shall have balusters or ornamental patterns such that a 4" diameter sphere cannot pass any opening up to a height of 34". From a height of 34" to 42" above the adjacent walking surface a 8" sphere shall not pass. As far as span the ICC does not have published in the current code span tables for a 4x12. For point of referance here in Florida the most common species of lumber used on exterior decks is #2 preasure treated pine. A single 2x12 spaced 16" o.c. can span 18'-10" at 40 40psf Note the blue highlight 34"- 42". I learned that the hard way after calling out the 4" sphere clause on a home that had a decorative railing where the top 6" of the railing was wider than 4". I had to eat my humble pie Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
The maximum 10' header span shown on the diagram conflicts with the IRC maximum 6' span.
| New Elec Code Requirements for Decks | jbushart | Exterior Inspections | 1 | 10/1/09 8:01 PM |
| Roof deck question | wdecker | Exterior Inspections | 3 | 11/17/08 10:17 PM |
| DECK FRAMING/CONSTRUCTION COURSE March 27, 2008 | ksitzes | Miscellaneous Discussion for Inspectors | 1 | 3/4/08 5:48 PM |
