Todays inspection presented no weep holes in the brick veneer. Not a huge area. 35 ft across and 2 storys high. 10 year old home. What are the concequences of not having these. I know many factors can come into play. Does anyone have experience in seing the end results first hand??
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
As to ramification, it all depends....too many variables.......I have seen homes that over 70 years old without any problem however that fact is that they were required to ensure proper ventilation and moisture management. Simply annotate same...... Hope this helps. Jeff |
Sean you will find about 60 % around here do not have weep holes , It is even enforced. Then you will find the ones full of mortar. I just note it and explain , and move on. if you can pull yourself from watching the tivo recorded soaps call me.
Jeff,
The house had a unfinished basement. I could see all the way down to the block at one corner so I know there were no weep holes. I do not know what was behind the brick. I do know Wayne loves to watch Lifetime, and paint his toenails Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
LOL
I really like it when Sean comes over to to buff them. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
I had one today with weep hole issues. What stinkin' weep holes??
LOL Linas did someone fill them ?
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Previous inspection report must have said
"Gaps in mortar - recommend filling them in" |
Linas,
It would not surprise me that an inspector make such a comment..... I have seen worse. Sean, If memory serves me, Tenn. has a GC license requirement to do projects of $25k or more which means there should have been some sort of oversight (code inspector) as the house was being constructed. I would be surprised that the builder failed to have weep holes on a 10 year old home.... they could have been covered or as Linas showed, filled in. Do you have any exterior pictures showing the foundation? Jeff |
| Brick weep holes | jshishilla | Exterior Inspections | 61 | 2/27/10 10:50 AM |
| To weep or not to weep! | rgant | Exterior Inspections | 14 | 2/15/07 12:40 PM |
| OK, Be kind. Newbie with alot to learn. | rcarley | Electrical Inspections | 23 | 12/3/06 2:00 AM |
