When I first saw this from the ground, I thought it was sap. When I got closer and touched it, there seems to be small amounts of sawdust.
It looks like when they were doing the stucco if it is, its hard to tell from here. But I have seen them cutting causing sawdust, while the stucco was drying (if you can believe that).
Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does your area require the tiles to be set in an adhesive?
It looks like the expanding urethane foam, which can be applied with a kit and a back pack unit or even by the can, similar to the Great Stuff foam expanding insulation gap sealer. Ed |
No adhesive requirement here. Thre are several areas across the fascia board that have this.
Any albino bats in Peoria?
If you knock that off Gary is there a hole? Insects??????
