Old 1/17/12, 2:52 PM
Default Anyone use MAT tubes?
Anybody use MAT tubes? Masonry Absorption Test tubes. Helps determine the absorption rate of water on veneer. Can help with a recommendation of properly sealing your brick/masonry.
...and, yes, I know it exceeds most people's SOP.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/17/12, 3:48 PM
Bob Elliott's Avatar
Default Re: Anyone use MAT tubes?
Jeff
Well we know Will does.
I just look at water stains the same way I do inside a bathtub enclosure as it does turn darker when wet but when you do a matts test you are after all just random sampling such a microscopic area at a time even if you position it at 100 spots.
Are you going to also climb a ladder and test at all levels ?
Just my opinion so far and usually this is found at multi-unit buildings where records of split block and CMU maintenance should be found hopefully.
Good luck and hope to hear more than I know from other users of this testing method.
Personally I would not get into this type testing unless assisting it with IR scans.
Old 1/17/12, 7:40 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Give Will a call. He can fill you in on all the details.
Good luck with your class next week Jeff.
Old 1/19/12, 1:16 PM
Thanks, guys.... and thanks for the luck, Linas!
Jeff
Jeff Wicklander
Prepare for the biggest housing boom in U.S. history. gromicko General Inspection Discussion 107 7/28/08 7:48 AM
25 cycle / 60 Cycle rcooke Electrical Inspections 7 2/9/07 9:05 PM
Drain? nbhi Plumbing Inspections 8 4/15/06 9:54 PM
