jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Anybody have any good report verbage for what appears to be asbestos siding on exterior.
The exterior siding has been recognized as one that may contain Asbestos and would recommend it be tested to verify it's content.
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
[Exterior walls] were covered with shingles of a type which has a high probability of containing asbestos. Confirmation of the presence of asbestos in the shingle material will require analysis by a qualified laboratory.
Asbestos siding may not necessarily present a health problem to the occupants of a house. Shingles are brittle and can be broken, split, or damaged. Repairs may be made by replacing asbestos shingles with cement shingles lacking the asbestos binder. To improve the appearance of cement or asbestos shingles, power wash, caulk at windows, doors, edges, etc. and repaint. If there is any question about the safety of the siding you should contact a qualified asbestos abatement contractor. Generally, asbestos containing materials do not have to be removed from any residential property. In fact, asbestos containing material does not have to be removed from any residential structure unless it will be disturbed during renovations or demolition activities. As long as the asbestos containing material is in good condition, intact and will not be disturbed, it does not pose a significant health risk. The only time an issue should be made of asbestos is when it's exposed and friable, flaking or crumbling, and that it's likely to become airborne. Removal should never be attempted by the homeowner. This action requires special equipment and detailed training, and is the last choice among alternatives because it poses the most risk of fiber release if not done properly. If removal is necessary it should be determined and performed by a qualified asbestos removal contractor. Don’t panic and walk away from the purchase of a good home, just because it might have some asbestos containing material in it. Educate yourself about the asbestos issues. There are many sources of information available: the library, the internet, government agencies, and asbestos abatement contractors are a few. There are two primary methods of dealing with asbestos containing material: Encapsulation (seal it in place) and Abatement (remove it). Visit: http://www.epa.gov/asbestos/ "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Thanks, both sound good. I was told not to mention it the report but I thought that would do no justice for the buyer.
Thanks |
Who told you not to inform the buyer about the condition of the house? You would be doing your clients a great disservice if you withheld vital information.
The clients can make their own decision based on the education you give to them, and any misinformation, or lack of information, can lead to a bad decision. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
The one issue I am foggy on is how does it get removed properly?
I know if I was buying the place I sure would get rid of it in favor of something bettor. No inspector speak answers allowed. |
Asbestos siding does not pose a health risk unless (of course) it's friable and falling apart. When I find broken or chipped Asbestos looking material, I simply recommend that it get encapsulated with a non-asbestos material. Most homeowners simply cover over it. It would be a massive expense to have the Asbestos siding professionally removed.
Cement asbestos is not a hazard provided that when it is removed it is not cut creating dust. The best way to remove is to remove it by hand.
A little description of what is required for Homeowners attempting to remove asbestos siding or roofing materials.
Asbestos Siding and Roofing Removal Guidelines for Homeowners General Based on a number of health studies, the inhalation of asbestos fibers is known to cause several respiratory diseases and research shows that asbestos in any form may constitute a potential health hazard. When untouched, asbestos siding and roofing present a minimal health hazard because the asbestos fibers are bound in a cement type mixture. However, because inhalation is the exposure route of concern, it is important to prevent asbestos fibers from becoming airborne. The health hazard occurs when the siding or roofing is drilled, sawed, sanded, or broken and the fibers are released to the air. The removal of siding and roofing can be legally performed by home owners, general contractors, or licensed abatement contractors as long as each does not violate the National Emissions Standards for Hazardous Air Pollutants (NESHAP) and work complies with Occupational Safety and Health Administration (OSHA) regulations delineated in 29 CFR 1926.1101. NESHAP regulations prohibit any visible emissions of asbestos fibers. As of October 1, 1995 changes in the OSHA regulations require a "competent person" to supervise all asbestos projects and a negative initial exposure assessments must be performed before employees trained in compliance with 29 CFR 1926.1101 can perform asbestos roofing and siding work. It should be noted that if the home owner has tenants then the homeowner is responsible for occupants other than the immediate family and the same regulations that apply to contractors applies to the homeowner. Before deciding to proceed with what is believed to be an asbestos removal project, be sure that the roofing or siding actually contains asbestos. This can be verified by sending a small sample for laboratory analysis. If the siding/roofing does contain asbestos, be sure to become fully appraised of regulatory requirements before beginning the work. If the material is or becomes friable, (meaning it can be crushed by hand pressure) then it can only be removed by a licensed abatement contractor or the home owner doing the work himself. It is important to note that even under the best circumstances these procedures can be physically demanding and potentially dangerous. Breathing through a respirator places an additional stress on the heart and lungs. Employers are required to have employees medically tested and approved by a doctor to use a negative pressure respirator. For individual homeowners it would be prudent to seek a medical opinion prior to wearing such equipment. Protective clothing can become hot and restrict motion, requiring added care to be taken when working on ladders and in high places. Eye protection may result in reduced visibility. Caution must be taken around live wiring and electrical power when using the misting (water application) techniques to prevent visible emissions of asbestos fibers. The homeowner (or contractor removing the material) is responsible for determining the condition of the asbestos material. If the asbestos siding or roofing is "non-friable" (meaning that it cannot be crushed to powder by hand pressure), the law considers it to be a solid waste which requires special handling and can be disposed of in landfill approved for that purpose with consent of the owner/operator. There are strict regulations governing how asbestos is to be packaged, labeled, and transported to landfills permitted to accept asbestos. Arrangements for adhering to these provisions should be made prior to starting the job of removal. In making a decision regarding the removal of asbestos roofing or siding, the homeowner should utilize the following tests to determine the associated health risks. If any part of the siding or roofing material can be crushed into powder by hand pressure, it is to be considered potentially dangerous. If no powder can be generated by hand pressure, the material is probably relatively safe. The removal procedure to be utilized is governed by the type and condition of the asbestos material. If there is any question as to the type of roofing material confirmation should be made by laboratory analysis. The following strategy can be used as a guideline in developing a plan of action for removal and disposal of asbestos siding and roofing:
The process of asbestos removal involves several steps starting with personal protection, and advancing through packaging to terminal disposal. The basic steps are as follows:
In summary, there are three major responsibilities that the homeowner accepts when doing the work himself:
If I was looking for a home knowing all that expense and trouble was involved for what most likely is a small cheap middle class home I would not buy it.
Now how could I recommend my client do so?Hmmmmmmmm |
Most homeowners would take the recommendation of encapsulation hide the asbestos with vinyl siding and resell it without disclosure. That is why it is important on our part to investigate the hidings of the vinyl siding. What is underneath becomes the big question. Personally, I would not buy a house with asbestos siding unless the Lot, structure, condition overall, outweighed the cost of removing the siding. If anything, it would be a good negotiating item. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I would not consider it my decision as to whether or not they buy it. My job, as I see it, is to perform and inform the customer. Let them make the decision on buy. I take a fairly strict hands-off attitude about anything outside my inspection obligations. Customers will often try to engage me in helping them make the decision, or ask about the "value" of a home, or "Would I buy this house?" and my answer is always the same. Not my decision.
Once the client has been informed and educated as to what is legally involved in removing the asbestos shingles, do you think anyone in his right mind would attempt it? I know I would not, but the last word would come from the client themselves. We inspect,educate, report and move on. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
We've taken asbestos siding off , as well as covered over the top of it with vinyl. I'd never NOT buy a house because it has asbestos siding on it. I'd be more concerned about the house with vinyl siding , than ANY other siding. Too much has been hidden behind vinyl siding. I notice a lot of home inspectors are cautious of calling asbestos siding "asbestos siding". Here's a little tip for all you unsure home inspectors. If the entire house is covered with asbestos looking siding shingles , most likely it is asbestos. I use to install asbestos siding. I've also done many asbestos siding repairs. Then the time came when asbestos siding shingles could not be bought for repairs. For repairs , the siding suppliers had what they called a mineral siding. It looked like asbestos siding shingles. NO ONE put asbestos looking mineral siding on the entire house. It was only used for repairs. Scott
Another note and that is on many older homes in my area asbestos siding is most likely to be the second layer of siding, usually over clapboards.
If this is the case then serious removal costs may be involved, #1 would you put a third layer of siding on a house, #2 if disposed of the cost can be somewhere around 800.00-1000.00 per ton, 3 if removal is the course of action you may have to remove the clapboards as well because you cant strip the asbestos siding with out pulling the clapboards with it. A simple 20 square siding job could turn into a 30,000.00 exterior renovation project. |
| Asbestos | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/26/07 11:11 PM |
| Asbestos | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/26/07 11:09 PM |
| Asbestos Still Legal, Dates of Bans | Stephen Masek | Ancillary Inspection Services & Additional Topics | 8 | 1/17/07 8:26 PM |
| Is this a competent asbestos removal job? Is our basement now a biohazard? | David Paterson | Ancillary Inspection Services & Additional Topics | 5 | 1/16/07 7:16 PM |
| Mould v. Asbestos | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 30 | 1/15/07 10:35 PM |
