Old 11/1/06, 3:43 PM
jwisecup's Avatar
jwisecup jwisecup is offline
Please Note: jwisecup is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Asbestos Siding
I have an inspection booked for tomorrow on a older home with asbestos siding.( per the seller) My client is the buyer and has expressed concern about this. He stated that the seller told him that you can install new siding over existing.
My question is..wouldn't the install of new siding over asbestos siding require
some type of disturbance to old siding-as in some type of nailing or furring strips at least? I haven't been around any re-siding jobs, so I am not sure what is required.(I do know that the distrubance of asbestos is not a good thing )
What do you all think, is this the seller trying to put a good spin on a potentially bad situation or what?
Old 11/1/06, 4:26 PM
ldapkus ldapkus is offline
Default Re: Asbestos Siding
To apply siding over the asbestos siding, you would create a fiber release when you nailed or screwed the new siding into the asbestos siding. The only way to determine that the siding is asbestos is through laboratory analysis. I worked for 15 years with asbestos abatement contractors and know what it looks like but I don't refer to it as asbestos unless it has been analyzed by a lab. Lab analysis utilizing Polarized Light Microscopy cost about $25 per sample but you shouldn't just break off a piece and send it to a lab for analysis. There are certain protocols that need to be followed when sampling PACM (Presumed Asbestos Containing Material). Depending on state laws, a siding company may not re-side a home that might have asbestos siding. It may not be a big issue ,but cover your *****.
Old 11/1/06, 4:44 PM
jwisecup's Avatar
Thanks Linas-thats pretty much what I thought.
Old 11/1/06, 8:31 PM
Brian E. Kelly's Avatar
If the siding is not damaged or broken just paint it. My parents 1940's home is sided with asbestos siding, painted with lead based paint. If your client is worried contact a local siding contractor in your area and ask them how they normally handle it.
Old 11/1/06, 8:46 PM
Exactly;
And if this is not appropriate, strap it with furring and re-side it.
Asbestos siding is a non-fryable product if it is asbestos content and nailing through it will only split it and break it, but will not create dust that will release harmful fibers.
JMHO of experience factor. 1984
Marcel
</IMG>
Old 11/1/06, 9:42 PM
John Nosworthy John Nosworthy is offline
We have a lot of post ww II housing stock with "asbestos" siding in place. Very weather durable material that wears well and holds paint well. I shoot it with an XRF frequently, have for years now, and most times it is NOT lead based paint. No need to have wasted the "best" paint on something that would never rot! They are not very impact resistant, and a pain to drill. It takes a punch tool/ cutter to properly work with the material, to make your nail holes, etc. Folks around here purchase the Canadian made replacement cement product, felt strips and nails, for repairs. You can usually rent the punch tool where they sell the cement replacments.
Around here vinyl siding is the preferred exterior make over material. Most installer "enclose" the asbestos behind a layer of fanfold (1/4" insulation, unfolds like an accordian) It's pretty effective at trapping the corner pieces that breakoff and can otherwise interfere with the lock of the vinyl courses. Also, little dust if any makes it past the fanfold, even during installation. Some place a bead of caulk continuously around the sill plate as they secure the fanfold, keeps any pieces from vibrating down and peeking out the bottom. Personally, I wouldn't worry about it. Like lead paint, ACM is not a hazard as long as it remains "intact". In my opinoin it is less hazard left intact on the dwelling and sided over versus removing and hauling to the landfill. Furring strips are never used around here.
my two cents
john
Old 11/1/06, 10:00 PM
jwisecup's Avatar
Appreciate all your help! I will know more tomorrow after I see the place. If it were me, I would probably paint it. Keep the character of the old house and all. (of course cheap and easy appeals to me also, at least as far as home repairs) This home should be quite fun -buyer is also worried about structure and electrical. I fully expect to be there awhile and get some great defects pic's.
Old 11/2/06, 2:40 AM
John, what's XRF?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/2/06, 11:37 AM
KShepard,
that's lead paint lingo for x-ray fluorescence,
a handheld analyzer to measure lead paint
Old 11/2/06, 12:54 PM
John,
How much for the XRF? They were about $10,000 when I got my Lead Inspector and Lead Risk Asessor Certification about 10 years ago.
Old 11/2/06, 6:57 PM
didn't mean to steer this thread off course jwisecup. anyway, about 16 grand in 2000, plus replacement isotopes about every two years for me at a couple of grand installed. I was quoted 26 grand for the current version with all the bells and whistles.
Old 11/2/06, 7:21 PM
The Chicago Public Schools had a push to clean up the flaking paint problem and spent $95 million years ago, to scrape loose paint and paint over the lead paint. Contractors made lots of money painting over ceilings that had moisture intrusion problems until the city figured out that they should fix the roof leaks before addressing the paint issue. Lots of $$$ to be made if you know where to look.
Old 11/8/06, 2:37 PM
Patrick Bolliger's Avatar
No Surprise here Linas,
You know the "City that werks"..
Did you know that a Chicago public school employee "that paints" can only paint to a specific height in the (building) system... Call it job protection.. How about all those very old schools with lead, asbestos in use.. I feel sorry for all those kids that don't realize they get a double dose of it.. First at home then at school...and you wonder why these kids are failing...and need all these drugs .... Pour more money at it....not for the kids but for the "system"...
No wonder I am so DUMMBB...
A Cook County employee / painter....$75,000 a year!!! We have no money... No wonder!! ( Per there own records)... Benefits you and I will never have.....
Sorry on a rant...
Old 11/8/06, 8:10 PM
And now we can't get an election count.
Old 11/8/06, 11:31 PM
gmendes's Avatar
gmendes gmendes is offline
While on the topic of asbestos siding. I sometimes come across this myself and never refer to it as asbestos siding since it can't be confirmed until sent in for analyisis. Do you all use a statement to protect you *****ets when you believe it to be asbestos?
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/27/07 12:11 AM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/27/07 12:09 AM
Is this a competent asbestos removal job? Is our basement now a biohazard? David Paterson Ancillary Inspection Services & Additional Topics 5 1/16/07 8:16 PM
Mould v. Asbestos Caoimhín P. Connell Ancillary Inspection Services & Additional Topics 30 1/15/07 11:35 PM
