| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
I inspected this house today. It had 4 layers (yes four). One original from 1923 of wood shingles and three of asphalt. There were a number of vertical cracks in the shingles as shown, however, the grit was in good shape on the shingles. I would guess that they were not more than 8 to 12 years old. No attic access to check for ventilation but small gable vents were visible on each side.
Could these cracks be a manufacturer's defect? Obviously there would be no warranty claim with four layers. Would anyone recommend sealing these cracks to squeeze a few more years of life out of the roof surface or should I recommend time for a new roof? Thanks. Last edited by ngifford; 4/6/06 at 9:52 AM.. |
with that many layers it may never leak, but just to be safe, i'd recommend stripping the roof ( that's ALOT of weight on an old roof) and re-roof before it does leak. adding more matterial now could cause some structural sways and waves that will be even more $$$ to fix.
Neil:
The type of cracking present is generally indicative of a manufacturing defect. However, 3 layers of asphalt over wood shake may negate any applicable warranty. The weight of the roofing may also exceed the recommended allowance accounting for expected snow loads. This area is 2 layers Max with the snow load allowance. I do not see how Massachusetts could be any different. I would recommend further review along with obtaining estimations for Roof Stripping / Sheathing and Replacement at this time. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Cracked shingles | pwigle | Exterior | 54 | 4/24/09 12:52 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior | 9 | 2/15/07 2:19 AM |
| Moss growing on roof | ecox1 | Exterior | 43 | 1/19/06 10:57 PM |
