Old 2/13/10, 8:23 AM
Joshua L. Frederick Joshua L. Frederick is online now
Default Asphalt shingle damage
What causes this horizontal wear or cracking? House built in 1997.
asphalt-shingle-damage-158-westlake-dr.-edgerton-032.jpg   asphalt-shingle-damage-158-westlake-dr.-edgerton-036.jpg
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/13/10, 9:23 AM
gbeaumont's Avatar
Default Re: Asphalt shingle damage
It's hard to tell, but that looks more like mechanical damage from maybe a tree limb than a manufacturing defect.
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/13/10, 9:38 AM
Was it up near the ridge?
Were there similar marks on the othe side of the ridge?
Maybe something was straddling the ridge?
I agree with mechanical damage but seems too uniform and staight for tree limbs.
Larry Kage, CMI
231 929 3525
Old 2/13/10, 9:49 AM
Kind of- Upper 1/3
No, just the one area.
Possibly, but I don't think so.
There was a small tree in the area, but I don't think that's what caused them
Old 2/13/10, 9:50 AM
Some of the shingles were a bit "brittle" as well. If you look closely in the second picture.
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Too low on the shingle to be wind. Were these the only two with this damage?
Old 2/13/10, 10:54 AM
Bob Elliott's Avatar
Quiz time
how old would you guys say the tile is?
Old 2/13/10, 11:14 AM
Originally Posted by belliott View Post
Quiz time
What tile is that, Bob?
Larry Kage, CMI
231 929 3525
Old 2/13/10, 11:17 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Looks like they could possibly have been stuck together in the bundle. they are offset in the packaging and when it gets too warm they sometimes stick together causing damage like what is seen. Just one option, if it were just several in the area.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/13/10, 11:24 AM
jkiser's Avatar
jkiser jkiser is offline
Tend to agree damage is to uniformed could have been done when shingles were being installed. just by looking at pictures shingles don.t look to be real old I would guess 5-10 years
Old 2/13/10, 12:01 PM
John E. Mullarkey John E. Mullarkey is offline
There is a vertical crack starting in one of the shingles and the ends of the shingles appear to be in the first stage of curling. In SW Fla I would say the shingles are about 10 to 15 years old.
Old 2/13/10, 4:12 PM
Sean Fogarty's Avatar
It doesnt matter how old they are. When fiberglass is showing on the edges, then the roofs days are numbered. Several things can amount to wear on roofs. Pitch, manufacturer, application, weather conditions and debris growing on shingles. I have torn roofs off that were well over 20 years with no tar paper, and replaced only a couple of sheets of wood underneath. You would have never guessed the shingles were more than 12 years old. Then I have seen 12 year old roofs that look like crap, and almost worn out. I would say if they could get another 5 years out of thet roof they will be doing good
Sean Fogarty
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
www.homeinspectionknoxville.com
Old 2/13/10, 8:41 PM
I say 12 -15
Old 2/17/10, 12:33 AM
I'm judging by your photos that those are damage to two separate shingles. Because the have almost identical characteristics, I'd say manufacturing defect.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 3:59 PM
Shake shingle damage rbusch Exterior Inspections 9 10/26/09 10:07 PM
What caused this comp shingle damage? kshepard Exterior Inspections 6 6/11/09 1:19 PM
Asphalt Shingle Roof Fasteners rmurphy1 Exterior Inspections 1 3/31/09 4:22 PM
Asphalt roof shingle cracks. ngifford Exterior Inspections 2 3/26/06 12:47 AM
