The 2001 Florida Building Code calls for attachment of Asphalt Shingles:
"where the basic wind speed per Figure 1606 to 110 mph) or M-DC PA 107-95."is 110 mph (49 m/s) or greater, special methods of fastening are required. Unless otherwise noted, attachment of asphalt shingles shall conform with ASTM D 3161 (modified My question is: Prior to the adoption of the 2001 FBC what were the requirements for shingle attachments in the 110 mph areas? (And can this be found in the 1997 Standard Building Code?) |
For those that may be curious - further research reveals that
the answer appears to be..... The 1997 Standard Building code called for 6 fasteners for each shingle for areas where the basic wind speed is 100 mph, but did not call for shingles meeting the ASTM D 3161 Class F standard. |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Asphalt roof shingle cracks. | ngifford | Exterior Inspections | 2 | 3/25/06 11:47 PM |
