Old 4/2/07, 4:50 PM
gbrasseur's Avatar
gbrasseur gbrasseur is offline
Please Note: gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Bad install, lack of flashing?
Hello to all,
Your opinions are appreciated. What do you think could cause this roof to do this? Or do you think it is just a plain bad install by looking at the first two pics? I think the last pics just show the lack of flashing. Your thoughts? Thanks to those who reply.
ID:	10488   bad-install-lack-flashing-100_5011-small-.jpg.JPG
ID:	10489   bad-install-lack-flashing-100_5012-small-.jpg.JPG
ID:	10490   bad-install-lack-flashing-100_5014-small-.jpg.JPG
ID:	10491   bad-install-lack-flashing-100_5015-small-.jpg.JPG
Old 4/2/07, 4:59 PM
jwortham1 jwortham1 is offline
Default Re: Bad install, lack of flashing?
With the wierd windows and paint overspray, I'd go with a bad install.
I bet they got windows, paint and roof all done by the same company.
Jeffrey Wortham
ANS Inspections, Inc.
www.ansinspections.com
630.276.8440
638 Langford Drive
Bolingbrook, IL 60440
NACHI ID:04050181
Old 4/2/07, 5:04 PM
tneumann's Avatar
tneumann tneumann is offline
I'll bet it's a flip..........
Old 4/2/07, 5:06 PM
rmccullough rmccullough is offline
The shingles look as if the nails weren't long enough to hold, why it would lift like that looks like the flashing in that area is lifting or are those shingles and not metal in the transition area. Could have been that new gutters were installed also in that lifted up area. Or if they installed a new roof they may have been lazy and not insert the shingles under the gutter.
The valley is a poor job of a tight closed valley install or did they try to interlock the T locs some how? Never seen that done here in Colorado.
The siding is to close to the shingles and are you sure there in no step flashing that you might not have been able to see under there.
Any case trim the siding back and make sure there is step flashing and a GREAT paint job on the siding.
Old 4/2/07, 6:22 PM
Adam D. Cole Adam D. Cole is offline
Please Note: Adam D. Cole is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that two layers of roof covering?
Old 4/2/07, 7:24 PM
Gregg;
The guys are on the ball here with good advice.
You need to start inspecting newer ones. ha. ha.
What I saw, if it helps.
Bad install is an understatement.
sheathing missing or not continuous at gutter area.
8" Masonite siding.
two layers of roofing possible
No drip edge
T-lock asphalt roofing
siding to tight to roof and unable to inspect step flashing
Masonite siding observed as 12", 8", 6", what's up
Home Depot spray gun, ha. ha.
Wonder how many cars in the neighborhood have that color.? ha. ha.
Marcel
</IMG></IMG></IMG>
Old 4/3/07, 11:56 AM
gbrasseur's Avatar
Hey Marcel,
Not sure what you mean by the masonite siding (12-8-6?) Composite siding like that is the most common around here. T-lock is also very common. Not so common where your from there in Maine?
Old 4/3/07, 6:24 PM
Originally Posted by gbrasseur
Hey Marcel,
Comment was made from your last photo that appears to indicate an exposure of the siding from approximately 12"-8"-6".
Just caught my eye and curious as to why since I don't see the whole picture as you did.
Good job Gregg, keep it up.
Marcel
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 11:54 PM
Question about chimney flashing waksell Exterior Inspections 16 6/26/07 1:25 AM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 1:11 PM
Step flashing at vertical wall? jlybolt Exterior Inspections 31 2/12/06 12:40 PM
