I would like to ask your opinions on this cantilevered balcony. There are some gaps in the siding and it does look to be settling. Nothing severe but would it be advisable to suggest adding a support post at the corner. If so would a 4 X 4 post be sufficient.
Thanks!! |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I do not think it is settling But it is dropping i would suggest support for it
Problem here is why would you even think of suggesting a extra support with no knowledge of the support system that already exists..
Tell me what your exact wordage in the report will be. |
Front Balcony has a noticeable drop , Recommend a structural contractor to review and make the necessary repairs
It's sagging.
Report it. Leave the specific type of fix to others. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I dropped off a radon monitor to this house yesterday and I am doing the inspection Sunday. I spent 30 minutes walking around to get a head start on the inspection. Noticed a few issues and wanted to inquire about the balcony.
Thanks!! |
I would call it out for evaluation just for the fact that there is a post supporting the roof with no visible means of transferring the load to the ground.
I am with Michael on this one.
David I am seeing a second floor balcony that might have have a post removed.
I really see or have built,cantilever balcony's built without posting support. I see the building is per 40's (just guessing ) and has had upgrades. I would have loved to see the lower portion where the entry stairs enter the home for more information. My opinion. Removed post. |
When you do your report and next time you run into this.
Remember to look into and mention the roofing component that is also being compromised. Rafters etc. How you fit it in is up to you. I agree with you that you should be looking into why to be a better HI. But as others mention before that and you have SOLID UNDERSTAND. Stay away from explanation. Litigation can be damming if you miss. Hope it helps. |
Here is a full picture of the rear of the home. I take lots of pictures.
I was only dropping off a radon monitor and I am doing the inspection tomorrow so back off on the comments about being a better home inspector. |
David did you actually measure the angle of sag?I can not see sag from the pictures
From the pictures I see siding issues due to lack of kick out and also separation of the gutter at the roof above the balcony. |
Bob Take a look at the first pictures he posted
OK ,I did. Yes there is some sag (couple inches over 4-5 feet) ,however the siding damage also coincides with possible water intrusion. Wish to add that it is odd to have that post there and hope not for support ,unless that is a really good cantilever ,which it apparently is not. [ATTACH] [/ATTACH]
This building is not so old to assume that it was platform framing.
The porch is framed with 2"x6" and built on to the inside corner of the house. Look at the elevation of the balcony and where the box header would be for the first floor. It was known to be in this type of construction to suspend the porch from the roof framing and it appears that the porch is supporting the roof. The steel rod inside the wood post is doing the support of the porch and pulling down whatever it was attached to in the roof framing. This type of field engineering by builders was common in that era. Look at the picture and you will see the sag also at the roof line. Although this is all speculation, the roof and porch are sagging and a building contractor needs to repair. ![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Balcony issue | kdolin | Exterior Inspections | 4 | 11/21/10 5:18 PM |
| Balcony and railing certs | jshishilla | Florida Inspectors | 4 | 6/24/10 12:58 AM |
| BALCONY Inspections in FLORIDA (Commercial) | jacaron | Florida Inspectors | 3 | 10/31/09 9:09 AM |
| Balcony FUBAR | jfunderburk | Exterior Inspections | 4 | 6/25/09 6:27 AM |
