Old 8/14/09, 5:26 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Band joist
What do you about this attachment?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America)
Old 8/14/09, 5:28 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Band joist
I would have to question if that single 2x is strong enough to support that weight. I would think that it would at least be doubled up.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 8/14/09, 7:23 PM
The only thing holding it are the bolts!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/14/09, 7:26 PM
John Evans John Evans is offline
The load is carried by the two bolts, I assume there is at least one more post not shown. Support columns should be notched for the beam or rim joist to carry the load.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 8/14/09, 7:39 PM
Before you critique the deck based upon the bolts.......do you know how strong those bolts are?
Old 8/14/09, 7:48 PM
Show them this if it helps.
Old 8/14/09, 9:28 PM
Marcel Gratton's Avatar
Marcel,
*The image above depicts a girder improperly relying on the sheer strength of lag bolts. Girders should bear directly on posts.*
On The Level Inspection
Gatineau, Québec
Old 8/14/09, 9:32 PM
I did.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/14/09, 9:35 PM
I know, it did not copy right.
Thanks for bringing it up.
Girder-post connection (incorrect).
Uploaded June 16, 2009
Old 8/14/09, 10:44 PM
It's OK now, but everything installed in a home is in the process of deterioration. It's a matter of how much sooner it will fail due to the method of installation. When all the parts are new the connection should be plenty strong judging from the photograph.
The way that single 2x girder carrying deck floor joists will fail is that the end grain of the girder will absorb moisture at a higher rate than the sides and edges. This means that the end through which bolts (or lags) are installed will be the first part of the board weakened by decay.
As decay becomes advanced the board will split along the grain line which intersects the bolt holes and at some point will fail under a load, probably an impact. Probably dancing!
If the girder were notched into the post failure would be delayed.
In the report, I'd call it "lower-quality framing and a poor quality bolted connection which will fail sooner than a proper connection." The lower quality framing refers to the single 2x girder which in quality framing would have been doubled.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 8/15/09, 6:04 AM
Unmoderated Guest
It's not a band joist at all. It's a grider. The memeber parallel to it and seen in the phots above it is the band joist or rim joist. he rim joist is not a load-bearing member at all, but of course the girder is. As has been stated, a bolted connection where the girder does not also bear directly on a post is incorrect.
Old 8/15/09, 6:09 AM
Thanks!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/15/09, 8:42 AM
Jeffrey R. Jonas's Avatar
Buck,
Do you have another photo, of the other side of that 'board'? Also, maybe one (overview) of the entire structure? Something nagging at me, but don't know what, yet.
Jeff
Old 8/15/09, 8:49 AM
Originally Posted by jjonas View Post
Buck,
Jeff
Jeff, maybe it's the potential for the rim/band joist to be bearing on the beam and/or post (behind the bolts) thus carrying some of the joists load?
Larry Kage, CMI
231 929 3525
Old 8/15/09, 8:58 AM
Yes, it kinda looks like it might be.
