Old 3/14/10, 12:30 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default A Beam that has twisted supporting a deck...need advice
The deck is bolted to the house. The columns are in good condition.
The supporting beam has a serious twist in it. The deck feels secure.
Should this be written up as....stay off until repaired?
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/14/10, 4:22 PM
Bruce A. King's Avatar
Default Re: A Beam that has twisted supporting a deck...need advice
It looks like the joists and the beam are too small but I don't know the total size of the deck etc. Is the beam twisted or just offset or both? Looks like enough of an issue to recommend a deck specilalist.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/14/10, 4:52 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
I'd have a structural engineer comment. I see no diagonal framing or bracing installed. NACHI has a deck course you should look at.
http://www.nachi.org/deck-inspections-course.htm
Ron Chorey
LAS CRUCES Home Inspections,LLC
Las Cruces NM
88005
575-640-0795
NACHI Membership 04070981
www.lascruceshomeinspections.com
Old 3/14/10, 6:50 PM
Post supports are spanned to far, no diagonal bracing, unable to determine span of joist however most 2x6 joist should not span more than 8 ft; 2x8 spans around 12 ft depending on species.
Pressure treated material often will twist / warp.
I am sure there is quite a few other issues that we can not observe....
A licensed GC should evaluate the deck.
Old 3/15/10, 9:05 AM
thanks
Check The Deck wdevries Canadian Inspectors 1 7/9/08 2:00 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Deck Failures rcooke Miscellaneous Discussion for Inspectors 29 10/25/07 5:47 PM
