New Construction - 2006... Roof decking is 7/16 OSB (Stamp rated at 16/24) Trusses at 24OC, No plywood (H) clips installed. Since its stamped for 24OC, and the trusses are at 24OC would you infer that the lack of H clips is no big deal or within the manufacturers specs?
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Peter,
Because you asked the question I would assume that you would recommend them. So what would keep you from recommending them? I would. Nobody's gonna put them in at this stage of the game but so what? John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
I guess my point was,.. its installed within the material accepted guidelines (i.e. by the APA stamp on the OSB for 16/24OC span.) If I called out a "lack of H clips" would the builder/ contractor make you eat crow by pointing out the very obvious,... i.e. the APA stamp?
The answer lies in table R503.2.1.1 (1) of the 2003 IRC. Looks to me it could go either way. No big deal as you say.
It is recommended for the H clips - but sounds like it's all done within manufacture specs, as you stated. Not a big deal, it allows for proper edge spacing & should be fine. Your call!
Michael Byrd Byrd-House Inspections Belpre, Oh |
| Michigan economy takes a beating | jburkeson1 | Miscellaneous Discussion for Inspectors | 4 | 5/28/07 3:12 PM |
