Old 8/9/09, 10:22 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Brick issues
This house has brick veneer with 2 issues. The brick has several areas of cracks. I do not see a pattern other than they are just in different areas. What causes the cracks?
The second issue is the discolored brick. There are a few areas of what appears to be spalled brick, that is discolored. I do not see any signs of moisture on the interior or exterior, but I can't see behind the finished walls.
Why the discoloration?
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Find an InterNACHI certified Mississippi Home Inspector (and anywhere else in North America)
Old 8/9/09, 10:51 PM
Bruce A. King's Avatar
Default Re: Brick issues
Looks like factory defects, I think a similar thread was on here about 6 months ago
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/9/09, 11:33 PM
Doug Edwards's Avatar
Looks like normal cracks in the bricks from shrinkage when they are fired and the discolored ones looks like what happens when the impurities burn off in the firing process as well.
http://www.onlinetips.org/causes-brick-spalling
- John Stuart Mill
Old 8/10/09, 12:05 AM
Thanks for the answers guys. Doug, thanks for the link. I think I will just recommend that they have the brick layer take a look since he has to repair the chimney anyway.
Michael Merino
Old 8/10/09, 12:41 AM
Joe Funderburk, CMI's Avatar
The "discoloration" is an aesthetic issue. For me, it would be beyond the scope of a home inspection.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/10/09, 6:26 AM
David P. Valley's Avatar
Those defects are minor compared to my find...
Old 8/10/09, 11:39 AM
I think you are correct, David!!
Michael Merino
Old 8/10/09, 12:31 PM
William J. Decker's Avatar
Mike;
Older, "Chicago common brick", most probably reused after being salvaged.
The problem is that this old brick was orginally installed using lime putty mortar and not the now standard N type portland cement mortar.
The problem is that N type mortar, especially when the masons add sand, is really absorbent to moisture. The water gets wicked into the mortar joint and passes behind the brick. During drying (in the winter) this moisture comes back out, through the brick, and you get spalling and flacking. For this older brick, they should use a lime putty or lime based mortar.
You see it, alot, when you have an older building (1920 or older) where they re-built the parapet walls. They use N type mortar and the repair disintigrates in about 5 - 7 years.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 8/10/09, 1:32 PM
This house was built in 1976. How can you tell this is the "Chicago common brick"? Most of the defect is located on the North side of the house, I remember something about the North side will dry out last after rains. Is the fix for this to use lime putty or based mortar when the bricks are replaced?
Michael Merino
Old 8/10/09, 8:48 PM
In that case, please disregard my prior comments. This looked like an older house. In this case, the brick was cheap.
Hope this helps;
Will Decker, CMI
Old 8/11/09, 12:08 AM
Will, I got a better answer. Cheap brick and the lack of weep holes and wicks. I think that moisture is being trapped in the wall between the Brick veneer and the CMU. Also, without the weep holes the pressure rises in the cavity and forces the water towards the exterior, causing freeze/thaw cycles and spalling and cracking. Just a hypothesis.
Michael Merino
Old 8/11/09, 5:36 PM
So this is a brick veneer, masonry structure house? Indeed! You need flashing and weep wicks.
Will Decker, CMI
Why do brick spall? mbryan Exterior Inspections 68 9/1/11 10:10 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 9:20 AM
Brick go boom??? ccarrington Exterior Inspections 11 4/24/06 1:25 PM
Massachusetts Clay Brick Education ajalowsky Miscellaneous Discussion for Inspectors 2 2/22/06 6:34 PM
