Old 6/7/06, 11:04 AM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
Default Brick Ties
Whats the spacing requirements for brick ties?
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 6/7/06, 11:09 AM
Doug Edwards,  CMI's Avatar
Default Re: Brick Ties
I believe the answer lies somewhere in here.
www.bia.org/BIA/technotes/t44b.htm
Old 6/7/06, 11:32 AM
gbeaumont's Avatar
Hi to all,
I believe that the spacing minimum is every 18 inch vertical and 32 inch horizontal, or a minimum of every 2 3/4 sqft of area.
The requirement is for more ties in areas of high wind or siesmic activity.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/7/06, 11:46 AM
Table 1 in the above website shows for wood stud (and steel) 18 inches vertical and 32 inches horizontal (maximum) spacing. Sounds reasonable as you would want brick ties to be installed on wall studs, in this case every other stud (using a 16in. O.C. spacing for studs.) Gerry beat me to it but...out of the mouths of two or three witnesses....
Old 6/7/06, 7:43 PM
Brick tie spacing, Hmmm.
I believe it is 16" vertical and 24" horizontal or 24" vertical and 16" horizontal.
Locate anchor sections to allow maximum verticall differential movement of ties up and down.
Install additional anchors within 12" of openings and at intervals, not exceeding 8 inches, around perimeter.
24" horizontal spacing of anchors would occurr on 24" o. c. spacing of wall framing, and equally, 16" spacing would occurr on 16" framing.
Marcel
Why do brick spall? mbryan Exterior Inspections 68 9/1/11 11:10 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
Brick go boom??? ccarrington Exterior Inspections 11 4/24/06 2:25 PM
No Brick Ties - Wall Buldge Stew Structural Inspections 1 4/22/06 7:56 AM
Massachusetts Clay Brick Education ajalowsky Miscellaneous Discussion for Inspectors 2 2/22/06 7:34 PM
