Old 12/4/07, 1:57 PM
David C. Macy's Avatar
Default Brick Veener & weeps
How would you report on the following conditions.
Home was built in 2001.
No weep or drain holes present.
How would you report on the exterior corner below the brick veener?
No indication of moisture in the unfinished basement below the veener walls.
Would you have a mason evaluate?
ID:	16494   brick-veener-and-weeps-109407-007-small-.jpg.jpg
Old 12/8/07, 5:21 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Default Re: Brick Veener & weeps
Looks like spalling of the brick due to the the earth in contact with the brick.
Moisture wicks up from the earth then the spalling occurs during the freeze thaw process
Suggest lowering grade or installing a waterproof membrane between the earth and brick.
I think Will Decker has a photo(in one of his powerpoint shows) of what might occur to the sill plate if this is not corrected.
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 12/8/07, 11:41 PM
David
Is that blue color indicative of foundation insulation foamboard below grade. I know your area probably won't have S/T activity like my area, but trapping moisture behind Vinyl and up to and/or behind the brick veneer and against wood structure is always trouble in our area.
Weepholes are required, installed more times than not, but AHJ typically won't call'um on it if left out. On occassion, AHJ has made the Bldr.drill and install, but rarely. I will note in my report if exclued.
Why do brick spall? mbryan Exterior Inspections 68 9/1/11 11:10 PM
Backfill on brick veneer bpaull Exterior Inspections 4 7/12/07 8:40 AM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
Brick go boom??? ccarrington Exterior Inspections 11 4/24/06 2:25 PM
Massachusetts Clay Brick Education ajalowsky Miscellaneous Discussion for Inspectors 2 2/22/06 7:34 PM
