I see alot of brick veneer some adhered and some anchored that goes right into the soil with no 4 to 6 inch gap. Especially the adhered decorative four foot walls in front of house that has grass or the garden up against the block. My question, is there supposed be a gap between all brick veneer walls and soil. Up here in Minnesota it seems most of them don't have them.
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Any building constructed since 1970 should have rubber, plastic or metallic "flashing," a protective skirt that curves around joints to protect against moisture. When water does get through a wall, it collects on the flashing and is released through "weep holes," small openings in the masonry. These holes are most obvious at the top of the foundation wall.
3/16-inch-diameter weep holes every 33 inches at minimum, just above the flashing . Flashing, in turn, is recommended under the first course of masonry at ground level, above windows and doors, below window sills, and at any lintels and shelf angles Since weeps belong just above the foundation your picture represents an issue. |
In the pictures I'm not concerned about the weep holes being able to drain as the amount of water they usually deal with is small and will eventually get out into the upper soil layer but.....what's going on under and behind the brick flashing? Is water moving by capilliary action between it and the concrete it lays on? Is the concrete under the brick and flashing becoming saturated? |
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Brick veneer flashing | mklein | Exterior Inspections | 6 | 2/21/10 4:20 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 7:40 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
