OK, maybe I am having a brain fart but why does the lintel appear short as in not going across the top of the door and window frame at this turn buckle balcony and continuing into the surrounding brick for support ?
No end dam either. 2006 build and from what I can tell the others are the same. This is a Bank Owned Condo Building and obviously if this is an an issue the client is not about to pay for an SE ,so any suggestions? or am I being over concerned here? [ATTACH][ATTACH] [/ATTACH][/ATTACH]
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What type of construction is this Bob? Wood-frame, steel-frame, CMU or (as it appears) is the brick/masonry actually the wall, and not a veneer? Also, why would you refer an SE for a masonry issue?
At first thought, a steel hanging lintel came to mind, but even those will have a typical 4" of bearing on each side of the opening.
The next possibility is a steel beam with a flat plate welded to the underside of it that extends out to pick up the brick, it's thickness might not have allowed it to bear on the brick. Further information would be required and Jeff said. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry out and about but as title states it is Brick veneer.
CONDO UNIT inspection. I think Marcel has the right idea but look at this flashing Most likely CMU behind it. |
Bob, most brick veneers with CMU back up have loose steel lintels that bear on the brick on each side.
Some steel brick angle lintels are also bolted, but again bear on the brick on each side of the opeing. I guess this one is wrong or a design that I have never encounter in commercial building to date. Something has to support that angle. Hanging steel lintel Bolted steel lintel to CMU back-up Loose steel lintel How old was this building. Most codes now require a steel relieving angle every 24' in height. Curious on this one Bob as to what supports it. The flashing extends beyound the angle in one picture and not visible in the other. Was that the same window opening.? Don't see weep holes in the soldier course either. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks guys, out e. Joying fests and as also in first post it is 2006.
Will add more tonight as I am still on it. |
Missed the 2006, wow, would be interesting to see the design drawing on that one.
Typed too fast to get the question posted on my way out. |
Marcel it must be your first thought as far as lintel extension goes but wanted to hear it from someone else. They must be using the CMU to hold up the lintel as if it was a shelf. Do not always get enough wall structure or structure access during a condo examination as most of you guys know.The interior public garage was CMU with brick veneer which actually means nothing but supports that the entire building may be CMU as it is only 3+stories. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 8/7/11 at 10:20 PM.. |
That lintel should have carried over 4 inches in both directions.
Support the load and bond the brick plains. It might be anchored into a metal beam work to carry the loads above it . http://www.nachi.org/forum/f16/bridge-too-far-35125/ Attachment 47179 Ether or that situation should have been addressed. Sometimes you can not carry the lintel over. Foam doweling and expansive caulk are used to adsorb the expansions, contractions. My 2 cents. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/5/11 at 10:36 PM.. |
Could not put a bore scope in the opening Bob?
Expansion joint. Typical on iron work setup. Could be a iron beam retro fit just for the baloney section. If not then bad window installers. Attachment 47180 montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/5/11 at 10:36 PM.. |
Robert that is not an expansion joint but is part of the turnbuckle support.
Also I have never seen an expansion joint near a corner before unless it served as a transition to face brick for instance. I think this is covered with the information I have so far. |
Being only a unit inspection I am going to suppose that the lintels are supported by something other than the window and door frames as there would be damage much worse than the mortar cracks Observed .
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Wind Mit? Brick Veneer | rwelch | Florida Inspectors | 15 | 5/4/11 1:29 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 7:40 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
