Brick over frame, new construction in Florida, should there not be screen in the weep holes?
Thanks! John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Be lucky there is some type of weep hole. Most of the time I do not see them at all. Could there be some under the mulch?
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
they often look like that John if they bother to put them in at all...
Yes
There should be a pest screen |
Never seen one. Not aware of any c#de calling for one. Bob, please cite your source.
You could make a recommendation for them (retrofit) and call it good:
This must be the Code Inspector Blog. John just in case you are not doing a code inspection and want to keep out pests they are a good idea and good practice. IMO they are local codes but since I am not a code Inspector I recommend them as good practice. http://en.wikipedia.org/wiki/Weep_hole http://www.encyclopedia.com/doc/1P2-8611044.html http://activerain.com/blogsview/1293...re-weep-holes- www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 2/17/10 at 6:14 PM.. |
I don't know about your area, but shouldn't there be more clearance between bottom of those bricks and ground.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Calling out the absence of something that isn't required and is RARELY seen (rope is all I've ever seen, in small diameter holes) is going a little too far outside the scope for me. Let them hire a bug man if they have problems down the road.
(P.S. What device do you use to keep the pests out of a home on a crawl space--the entire subfloor is accessible. Anybody note the potential problems there?) “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I've never seen a pest screens either. Might start recommending cigarette filters be inserted in weep tubes to keep the pests out
that looks pretty slick Larry....do you have any experience with these..I always see them open here if at all, but that doesn't look like a bad idea... |
Buck, are you really trying to make people believe that there are suppose to be screens for weep holes..............please go back and take some construction courses so you know what you are talking about........ if it were not so pathetic it would be laughable........ you post pictures calling stuff out where there is nothing wrong or are asking for advice on how to word stuff I suppose because you are not really sure what is wrong.......... now it seems you are giving or inferring stuff for which you do not know what you are talking about.
John, Like Joe said...... there is no requirement for such a thing......the only reason they use rope is for expediency......the rope will eventually rot away leaving there required size hole which is 1/2 inch in diameter. If a screen were to be inserted, you can rest assure that it will fill up with debris. The purpose of the weep hole is to help alleviate any moisture build up between the brick veneer and wall sheathing and quite frankly I have never seen moisture run out of a weep hole but rather allows air to flow between the cavity which should be about 1 inch between the veneer and sheathing. The location of weep holes are at the first floor band joist level and over all doors and windows. There should be an approved flashing membrane that is attached to the wall with an moisture barrier overlapping the member. The flashing membrane then lays upon the brick foundation so that moisture does not enter on the crawlspace but rather allow same to escape to the exterior. Weep holes are often located every 4 feet. Be careful not to become an an inspector who think he is an engineer and end up calling out all sort of crap which doesn't exist....... ..those type end up looking stupid, and it gives validity to the many complaints from GC and RE boards who contend that many HI's dont know what they are doing. Here in North Carolina regulations have been adopted which are handicapping how inspectors perform their inspections......... unfortunately much of it is the fault of inspectors who don't know what they are doing and/or think they are GC or Engineers. (you can understand why I an adamant about stuff like this). Hope this helps... regards. Jeff |
Its amazing at some of the crap (bad advice) I have read on some of the forums lately........... I understand that HI's are not required to be GC's however some would do well to take some basic construction courses to get a better understanding of what they are inspecting especially in regards to foundations, exterior veneers and framing......those are the areas which can be costly one misses legit items. How are things going in SC.......also did you ever get that phased construction job I sent your way? Jeff |
| Brick Veneer Walls - Weep Holes | jbowman | Inspection Question of the Day | 20 | 4/28/08 2:09 PM |
| Brick house | nbhi | Exterior Inspections | 28 | 2/17/08 4:22 PM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 10:20 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 7:34 PM |
