Buldge in stucco is observed just above the bottom plate the entire lenth of the two exterior walls. Shotty framing? A horizontal crack is also observed above and below the buldge...see photos. The stucco is also very poor quality, basically disintigrates between my fingers, blows off wall in high winds, "stucco pellets" found all over the deck after wind storms...
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You have stucco in Manitoba! There's 90% of the problem.
Very funny..are you referring to our climate?
crumbling
sounds like it froze before it dried, and might have been painted before it was cured. "I create controversy whether they like it or not" |
Settling of framing.
In multi-story buildings, at each floor structure you have a conjunction of framing members...studs from the floor below meeting top plate, plywood/OSB sub-floor, and a bottom plate meeting studs from the floor above. When they're framed, there is a small gap between each of these framing members. That's 4 gaps. As the framing members dry to an in-service condition, they each shrink a little. If they each shrink 1/16 inch, that's a total of 1/4-inch in about 16 inches. Stucco doesn't shrink at that rate. So you have two different material systems that are attached firmly to each other with nails or staples that are moving (or not moving) at different rates and that's going to cause problems. When you look at the exterior of a multi-story stucco structure, always look at where you estimate the floor structure to be for this problem. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I would say "Yes".
Stucco was developed and widely used in hot climates. From Wiki: "In some parts of the United States (California, Arizona, New Mexico and Florida), stucco is the predominant exterior for both residential and commercial construction." |
First I would determine if the system is "Hardcoat, Traditional Wire Lath",or is it EIFS or DEFS. The bulge could be caused by more than one action depending on the system. i.e. If it's EIFS or DEFS, was it meshed across the board, if DEFS was it meshed at the seams How old is the system and when did the bulge appear. It takes more than a surface view to determine the cause, suggestion; "A bulge was noted in the surface of the Stucco system at (where?), unable to determine the cause during a home inspection, suggest a Stucco Moisture-Scan be performed by a qualified Stucco Inspector."
Mr.Kelly is making good sense here.
#1 your hypothesis on the system. #2 your hypothesis on the framing. I see a gutter near by. I would be try to draw a conclusion from the 2 sides, interior and exterior.. Framing and exterior envelope. A small crack in a hardcoat system would allow moisture in behind the framing. Did you see evidence of moisture staining on the plaster inside the unit? If not other conclusions can be drawn. Good luck. Not enough to go on. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Nice try, but the stucco was installed in the middle of summer when it was blazing hot. Temperature was around 32C.
98% of all stucco here is hardcoat, and this one is hardcoat. No water penetration or evidence of moisture to interior of home. I believe it is the framing...
Downspout is not leaking. Bulge runs entire length of both walls. No evidence of moisture into interior of home.
Any more photos Mr.Grabowski?
Just a hypothesis. Vertical load is causing the fasteners to fail and the plywood is coming away from the wall studding. There would have to be several factors at work. #1: the ply wood laid horizontally. No staggering heights.. #2: fastener's breaking. In the first photo it looks like that section of wall is also beginning to budge along a straight line. or is it my and or the photo? Did you notice and truss uplift? Any door or window frames out of square on the side of the home? Where the eve square, saw-fitting pulled away or compressed? Any way to get a bore-scope in a whole? Any more photos? montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Did you see the same problem all the way around the building? Does it rain there during the summer?
Didn't see the expansion / control joint at the floor line.
Not important why as much as refer to a competent stucco contractor for repair. |
You seen this before? montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| There are over 12 types of stucco and EIFS | bgromicko | Exterior Inspections | 0 | 12/19/09 7:04 PM |
| EIFS/Stucco | mmerino | Exterior Inspections | 16 | 8/6/09 7:41 AM |
| Stucco Issues | jfunderburk | Exterior Inspections | 19 | 3/7/09 8:15 AM |
| Bulge in stucco at 2nd story | sspradling | Structural Inspections | 18 | 4/6/06 8:45 PM |
