In Chicago, I see a lot of bushes against masonry walls. Since bushes against siding causes the wood rotting concern, should I report bushes against masonry as a problem?
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Oh, I thought you meant President Bush's daughters, Jenna and Barbara, falling down:
I prefer my bushes trimmed....and clean.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
I'll get Kenton to post a narrative for you tomorrow.
No..
Vegetation against exterior walls
Vegetation growing against the exterior walls may introduce pests and/or accelerate deterioration of the exterior wall covering by retaining moisture. Watering this vegetation will introduce moisture to the soil which may eventually reach the foundation. Moisture in soil supporting the foundation can affect the ability of the foundation to support the weight of the structure above and can cause damage from soil heaving or settling, depending on soil composition and other conditions. The Inspector recommends trimming or removal of the vegetation from contact with exterior walls. Consider replacement with vegetation having low water requirements. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
With Leon's question concerning brick/masonry alone, I see no problem.
Kenton's narrative is more elaborate concerning the house/building in general. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
You have never seen damage to masonry such as spalling due to the moisture in the wall freezing? Perhaps you need to move those shrubs out of the way more often! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Or you could write this....
.... write a check for $99 and buy 8,000 of Kenton's well-written narratives: www.nachi.org/narratives.htm
It's not the roots that are the problem in relationship to moisture and siding. It is the leaves give off moisture during transpiration. The brick is porous and absorbs the water. The bushes also abrade the surface but it's not as big of an issue with brick.
Brick is a reservoir cladding, meaning it holds water, but in addition to transpiration, leaves against the brick may slow drying.
| Brick veneer flashing | mklein | Exterior Inspections | 6 | 2/21/10 4:20 PM |
| Chicago Chapter Education Evaluation of Masonry Buildings | jmerritt1 | Miscellaneous Discussion for Inspectors | 3 | 11/10/09 9:02 PM |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
| History of Insulation with Masonry | mcyr | General Inspection Discussion | 7 | 2/27/08 7:53 PM |
| Historic Masonry Re-pointing: Repair or Ruination? | mbryan | Exterior Inspections | 5 | 2/21/06 9:49 PM |
