I called it Metal Base?
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
what is this part of? a car port, or a railing?
Jahr Vaagen Totally Inspected 618 Howard St. Bay City, MI www.totallyinspected.com "When my job is done, you'll be Totally Inspected!" |
Well, 1 out of 3 ain't bad.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
(Kinda what I was thinking Marcel I will post the Mushroom on the Eaves when I get home later. |
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
The 3rd pic looks to be a "stand-off" base, but pic's 1 & 2 do not.
Generically, they are all "post bases". Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
That is what Jeff referred to and that is what is installed in picture 3
The AB is an adjustable post base which offers moisture protection and finished hardware appearance. These post bases feature 1" standoff height above concrete floors, code-required when supporting permanent structures that are exposed to the weather or water splash, or in basements. They reduce the potential for decay at post and column ends. Material: AB – 12 gauge plates;16 gauge base cover; all others – see table. Finish: Galvanized. Some products available in ZMAX® coating; see Corrosion Information. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
the same Post Base "WAS" installed in all three pictures.
Just for some of you less seasoned guys, when the base rusts/deteriorates the weight of whatever the post is holding up pushes the post down. |
Were they buried, we don't see them.
I can not help but notice how more and more of these posts are getting cryptic as if guys are not sure and just make joking or generic statements to cover their bases.
Someone please speak English about what is wrong here and the correction as that it why we are all here. Marcel says 1 out of 3 ain't bad. What was that (reference to a Meatloaf song)? |
2 out of three of the Metal Post Bases were rusted/deteriorated and need to be replaced. 1 Metal Post Base is still functioning as intended. |
I had no idea those were 3 separate posts and had no idea if the issue involved lack of a poured footing,or wrong bracket as I simply noticed wood rot and was looking to see if the concrete apron was cracked being near a corner. |
well Robert seems to be in a pissy mood today.....I thought You guys don't get any moisture in death valley....did these people have a large male dog perhaps?
| CBC - Province called on to force home-sellers to disclose property's problems | rwand1 | Canadian Inspectors | 3 | 4/5/06 8:40 PM |
