I called this out for a roofer to look at...the agent sent another home inspector out the day after. He said it's good, no worries. ???
AND..I set a radon test out, the client calls me 30 or so hours into the radon test and expresses his concern about high radon. I was baffled and mystified as to how another home inspector could act as the roofer I recommended ...... and how the client would know the readings of the radon machine. Wrong in so many ways. Please share your thoughts....and what you would recommend on the chimney and on the situation. Thanks. Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! Last edited by twendorff; 8/12/11 at 11:27 AM.. |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The flashing is improper.
Why didn't you just state that it was improper and what is wrong with it rather than suggest that they hire someone else to get a second opinion? If you know that something is a defect, don't tell your client to have someone else come behind you to offer a different opinion. At this moment, they are probably wondering why they hired you. BTW: Unless the other inspector spoke to you about it directly or you saw his documentation first hand, don't assume that you know what he actually had to say based on someone else relaying it to you. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
same key works many of the machines , HI maybe took a peak, Flashing needs to be repair .
Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Improperly flashed chimney. There isn't supposed to be any exposed metal at the roof on the sides, and the junk on the upper side is bucking water.
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Let's see:
Agents send out another inspector to check out the flashing = one scared realtor trying to salvage his/her sale at any cost. Client says the radon is high = a client possibly trying to find an excuse to get out of his "contingent due diligence" period. |
Did you tell them why it was wrong OR just say something like "flashing is improper, have a roofer correct or evaluate".
With no guiidance, the agaent called THEIR home inspection guy and he simply said LOOKS ok to me. |
I did tell them why it's wrong...and I did recommend evaluation and repairs by roofer.
I'm comfortable with my report being correct. I'm just still in awe of the whole situation. Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! |
If I were in your position I would send a picture of a proper flashing installation to my client just to ensure credibility with them. People are not stupid and will see right through the Realtor's motives.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
That's exactly what I did this morning!
Tim, calling for evaluation by someone else should not be used in most cases.
It either needs repair or it doesn't in your judgement. If they want to find a more compliant opinion, that's their business. You are being paid for yours. Leave it at that. Good luck. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 8/12/11 at 11:59 AM.. |
I agree ,one illustration is worth 1,000 words.
I did state in the report that it is improperly flashed and that I recommend evaluation and repairs by a roofer.
Thanks for all your help guys! Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! |
Call for repair not evaluation Tim.
You have already evaluated it and found it deficient. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Timothy -
Like Michael said NOT evaluate / You did that. Service or Repair. You keep saying you told them it was IMPROPER, but what did you say to explain WHY it was improper? |
