Old 3/24/10, 1:02 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Carl Brown
These photos are for Carl Brown. They will never learn will they Carl! This in Piper.
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/24/10, 2:33 PM
Bob Elliott's Avatar
Default Re: Carl Brown
Buck,I am not Carl,but could you explain why number 3 would not work?
No gap but I am thinking if that makeshift flashing goes up and behind that it might work.
Please correct my thinking.
Old 3/24/10, 2:50 PM
Bob,
I always find water leaks around this type of flashing and stucco. What do you think about the flashing at the stone. It is under the roof overhang, might never leak.
Thanks!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 3/24/10, 2:55 PM
My first thought on that is not enough gap and not a good kickout.
Those stones do not look very secured either.
Old 3/24/10, 3:02 PM
Carl A. Brown's Avatar
When the front drip of the flashing is notched so is the back or it still would not make the radius.
Thanks Buck
Old 3/24/10, 3:03 PM
They are toooooooooo tight to call the heating and cooling co. to make to right.
Old 3/24/10, 3:04 PM
In the 4th picture the trim and the window is improperly installed.
Old 3/24/10, 3:06 PM
that is Lick and Stick / faux stone built to leak before the stucco/faux stone company ever got to the job, let alone what they probably did while there.
Old 3/24/10, 3:13 PM
Why bother doing it Right when doing it Wrong pays the same?
Examples
And most people have no clue what they are really getting into.
Old 3/24/10, 3:22 PM
http://www.badstucco.com/indexmb/slides/055_55x1.htm
Old 3/24/10, 6:43 PM
Thanks! Carl
I going to make someone mad over this one. House is less than 4 years old.
TOO BAD
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 3/24/10, 7:29 PM
Originally Posted by cbrown1 View Post
What about that flashing over the arched window in #3 Carl?
Old 3/24/10, 7:52 PM
The window is not flashed but the trim is, and that is another reason for water entering.
Old 3/24/10, 8:06 PM
Gotcha
Thanks Carl.
Old 3/24/10, 8:07 PM
At the sill down and out over the cladding.
At the head of the windows out over the window, and out to the outside of the vertical trim.
At the head trim.
IMO this is what they need and not just stucco!
Here
And backer rod and caulk has there place but they will never replace common sense, and proper lapping of products.
THANK YOU Carl Brown!!! badair Miscellaneous Discussion for Inspectors 7 7/10/07 10:24 AM
From Inspected to Inspector jhagarty Miscellaneous Discussion for Inspectors 0 3/26/07 4:59 AM
A BC home Inspector rcooke Canadian Inspectors 0 3/25/07 12:05 PM
