Carl,
Very seldom - I had to get you're blood boiling a little---Sorry----
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's like finding a needle in a haystack!
With the control joints...that could be PM EIFS/hybrid stucco. It absolutely looks like stucco but its polymer non-cementious based.
I'm curious....Did you knock on it? |
Dave, educate me on how you can tell it's polymer non-cementious based, just from the photo. Thanks! |
Sorry, I misunderstood your comment!
Control joints!!
Must have worked on that wall before the BEER JOINT! But still no backer rod and sealant joint around the window! "I create controversy whether they like it or not" |
With all your education in STUCCO, I'd like to see you come out with an educational video series on iNACHI TV. |
David,
That would never fly! The folks at ASTM have their heads in dark places! And the bulk of stucco problems can be linked to windows,flashing,and last but not least moisture barriers! Please do not get me started about AAMA! All of these are not installed by stucco contractors yet stucco gets the bad rap! Here is a link to the control joint! http://amico-lath.com/lath/expansion_control_joint.htm "I create controversy whether they like it or not" |
Thanks DALE!!!!!!
I'm referring to... http://www.nachi.org/advancedcourses.htm |
But the ex-perts in the various parts of the industry would say it was
mis-information. I would not want INACHI to get a black eye for my opinions! I think it was INACHI TV #33 that made my blood boil when I watched it. "I create controversy whether they like it or not" |
If homeowners could sue the city's for it would change things alot!
They do not need to because they sue the HI. And thats getting easier to do by what I have been reading here! "I create controversy whether they like it or not" |
Here we use Styrofoam, barrier, chicken wire( I push the palm of my hand against walls between studs to make sure there is 3/8ths of an inch of final product, which is required, sometimes the palm of my hand goes through the wall, Oops---- Which means there is not 3/8ths of an inch---- But I only push good and hard on new construction---- Older homes I knock and push normally---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Long Hairline cracks in a gypsum lath ceiling | rkie | Interior Inspections | 5 | 5/17/08 5:27 PM |
| THANK YOU Carl Brown!!! | badair | Miscellaneous Discussion for Inspectors | 7 | 7/10/07 11:24 AM |
| From Inspected to Inspector | jhagarty | Miscellaneous Discussion for Inspectors | 0 | 3/26/07 5:59 AM |
| A BC home Inspector | rcooke | Canadian Inspectors | 0 | 3/25/07 1:05 PM |
