I've inspeced many homes in our area and many of the 70+ year old homes originally had a cedar shake roof. I always explain to our clients that the gaps in the lap boards were very important to ventilate the attic and allow the shingles to dry out.
Ususally, when there is a re-roof, I see three different methods. Some roofers will do a tear-off and leave the cedar shingles, lay down tar paper, and install the composit shingles over the top. Other times, I will see a full tear-off and 1x's will be nailed to the rafters ro fill the gaps and then the new roof installed. Lastly, I will see a full tear-off and OSB installed over the oringinal deck and then installation of composite shingles (the best IMO). Please take a look at the pictures attached. I would like to know if this is a defect or not. The roof is approx 3 yrs old but I think the workmanship is very poor. There was a full tear off but the roofer did not fill the spaces in the original roof deck (built around 1900). What do you think? Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Find an InterNACHI certified Kentucky Home Inspector (and anywhere else in North America) |
Greg, I see roofing nails coming through the shingles where there is no wood to nail(the original gaps on the planking). What is supposed to hold those shingles in place during high winds? I would call it out as unprofessional at the very least. I am sure over threee years they have held up, but you never know. I would say that if they suffered any wind damage, and the manufacturer found them to be installed in this fashion( missing the planks, and nailed to nothing) they would not want to cover that.
Here's my oringinal note:
"There are gaps in the roof deck that should have been filled or a new deck should have been installed prior to the installation of the new roof. There are shingles where the nails do not properly penetrate the deck and could eventually work loose. These gaps were very important with a cedar roof but this will not properly support composite shingles. Recommend consulting with a professional, licensed roofer for further advice." Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Need you ask?
I just want to have other opinions before I call this out as a defect. As you know, being correct is most important. Who knows, maybe the roofer suggested to do it right and the seller refused?
(NRCA) National Roofing Contractors Association recommends that asphalt shingles be applied over continuous or closely spaced wood plank decking or wood decking. The planks currently in place are spaced to far apart. As a result parts of your roof covering are not attached properly to the roof deck and can easily be destroyed by unfavorable weather conditions. The most common materials used for roof decks are plywood or oriented strand board (OSB). When plywood is used, NRCA recommends the use of a minimum 15/32 thick or ½ inch nominal exterior-grade plywood for 16-inch rafter spacings and 5/8 inch nominal thickness for 24-inch rafter spacings. For OSB, NRCA recommends using a minimum 15/32 inch thick or ½ inch nominal exterior-grade OSB for 16-inch rafter spacings.
Caution should be exercised when roof decks are constructed out of the following materials:
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
Thanks, Bill. I think you mean to say 'spaced too far apart'. Does anyone know if there is a maximum spacing? Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
I would scratch on your original narrative where you call for a roofer to reinspect what you already inspected. Call them out for repair not reinspection.
Your to much
You talking to me Nick?
| Roof Top Deck Load | jevans | Structural Inspections | 17 | 7/30/09 12:15 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Cedar Shake Roof Inspection Today | gwilcox | Exterior Inspections | 10 | 4/1/07 12:14 AM |
