Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 11/1/09, 9:36 PM
Mitch A. Harris Mitch A. Harris is offline
Default Cement poured against Hardi Siding
Inspecting a new house to day, the porch cap and steps had been poured against the siding, no flashing observable. Every home on the street was completed in the same manner. I was under the impression that James Hardi and all other lap siding needed to have at least 1" of clearance above concrete. Has anything changed? It looks nice and clean, but in my book it's wrong. Please view the pics, and let me now what you think.
cement-poured-against-hardi-siding-hpim4208.jpg   cement-poured-against-hardi-siding-hpim4209.jpg   cement-poured-against-hardi-siding-hpim4210.jpg
[]Mitch Harris
Harris Home Inspections
mitch@harrishomeinspections.com
Your Central Kansas Pro-Sight affiliate
www.prosightinspections.com/HHI
Find an InterNACHI certified Kentucky Home Inspector (and anywhere else in North America)
Old 11/1/09, 10:29 PM
Default Re: Cement poured against Hardi Siding
Hi Mitch, hope all is well.
Well, they at least they did a good job with the concrete.
Masonry front stoops should never be placed directly against wood or siding of any kind, that is just asking for problems.
The rot won't affect just the siding, eventually, the sheathing will go, as will the framing. Even then, you'd probably think everything is just fine until the damage shows from inside. By then, you probably have attracted termites, which love to dine on moist wood. Even without them, repair costs will be serious.
The siding should have stopped short of the concrete steps to within an 1" and where the steps are should have had a complete water proofing system down to the foundation below.
An expansion joint should then have been installed at the butting area with a caulked joint to prevent water intrusion.
The best scenario would have been the to have the foundation higher in this area.
Cyr Home and Commercial Property Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards
Commercial Builder
CertainTeed
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
Old 11/1/09, 10:37 PM
Terry B. Clayton Terry B. Clayton is offline
According to thier website installation PDF http://www.jameshardie.com/pdf/best-...hz10-plank.pdf there should be a 1" to 2" gap between siding and other materials such as side walks and stairs and the same for roofing materials. Hope this is helpful.
Old 11/1/09, 10:50 PM
Originally Posted by tclayton View Post
According to thier website installation PDF www.jameshardie.com/pdf/best-practices/hz/hz10-plank.pdf there should be a 1" to 2" gap between siding and other materials such as side walks and stairs and the same for roofing materials. Hope this is helpful.
That is a good link Terry, and I agree with that detail that they show.
It is another one of these cases where they have the cart in front of the horse.
The steps and landing should have been poured way before the siding got done, then the flashing requirements would have come automatically. Well, I hope anyways.
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
Old 11/1/09, 11:29 PM
Thanks, Marcel and Terry for your input, I think that I will just include the link in Terry's post with my report. Might keep the builder from telling the client that I don't know what I'm talking about.
Thanks again guys,
Mitch
[]Mitch Harris
Old 11/2/09, 1:30 AM
Tim Spargo's Avatar
Yes, not so much the siding itself, but the moisture trapped behind.
Nice links!
They'll likely dispute or "soften" whatever you said if it's going to cost them a fair amount of money to fix. Who wouldn't? " Porch is covered!", "We'll install some flashing, he's right!", "Those diagrams are suggestions, but not end-all"
The client will make the decision and your job is done!
Tim Spargo
Home Inspection Lancaster CA, Palmdale CA Antelope Valley
Old 11/2/09, 8:47 AM
Scott E. Green Scott E. Green is offline
I see this all the time. Was the siding installed wrong? The answer is no. The siding was properly installed. The 1 - 2 inch gap is specifically designated to the installation of the siding. At the time of the siding, there were no steps. The steps were poured afterwards. Good thing it's cement siding, and not a siding of less endurance. Although a 1 - 2 inch gap is the recommended way of installing any siding, it's very seldom done that way, and it should be. Was it the masons fault? The answer is no. He came in and poured his cement. The mason is not a siding man. He could care less about the siding. He's a mason. One thing I notice all the time; The different trades are just that, different trades. As a rule, no trades person seems to care, or have knowlege of the other trade. This starts from the ground up. Placement of rain gutter drains, to siding, to roofs, to gutters, etc.. I can go on, and on. But don't have the time.
Old 11/2/09, 8:52 AM
Originally Posted by sgreen2 View Post
I see this all the time. Was the siding installed wrong? The answer is no. The siding was properly installed. The 1 - 2 inch gap is specifically designated to the installation of the siding. At the time of the siding, there were no steps. The steps were poured afterwards. Good thing it's cement siding, and not a siding of less endurance. Although a 1 - 2 inch gap is the recommended way of installing any siding, it's very seldom done that way, and it should be. Was it the masons fault? The answer is no. He came in and poured his cement. The mason is not a siding man. He could care less about the siding. He's a mason. One thing I notice all the time; The different trades are just that, different trades. As a rule, no trades person seems to care, or have knowlege of the other trade. This starts from the ground up. From rain gutter drains, to siding, to roofs, to gutters, etc.. I can go on, and on. But don't have the time.
That it where the General Contractor comes in. He needs to coordinate, with planning, the action of all subs. I used to call it babysitting.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 11/2/09, 9:30 AM
Hit that one on the head Larry, "Baysitting"
And that is exactly what it is. Done it all my life.
That is the biggest problem today, no one to coordinate the trades properly, so the cart is often in front of the horse.
Time is money and that is all they care about. Get ur done.
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
Old 11/2/09, 9:33 PM
I knew you could relate, Marcel...
Larry Kage
231 929 3525
Old 11/2/09, 9:46 PM
Stephen W. Stanczyk's Avatar
So how many of you that find this situation tell your client that any warranty the siding manufacturer may have could be void as a result of the incorrect installation?
Stephen Stanczyk
Structural Pest Inspectors License # 71043
Vice-President, Washington Association of Property Inspectors (WAPI)
Old 11/2/09, 9:48 PM
My thoughts exactly.
Old 11/2/09, 10:17 PM
I wouldn't tell anyone the siding warranty would be void. I don't see where this situation would void the siding. Things are not always text book perfect. For this specific situation, I would rather see the concrete poured against the cement siding, which goes all the way down to the bottom. Any water would run all the way down. If it were flashed, with 1 - 2 inch gap, like shown in the text book, water could run below the flashing, and on to raw wood. Then you would have real problems. So, in my opinion, I'd say it depends on all factors. Personally, I think they did a nice job.
Old 11/3/09, 9:15 AM
Kenneth Greene's Avatar
Kenneth Greene Kenneth Greene is offline
The real roblem occured when the builder exposed th wood framing to a location that would later have concrete poured against it. The siding guy did what he does, cover the wood with siding. That sidng is now trapped behind the concrete. So the real issue is with the builder and the lack of design detail.
No matter who the blame falls on it is an impropper installation of the right materials. Still doesn't make it right. I'd call it out all day long.
Hudson-Mohawk Inspections LLC
Ken Greene
NYS license 16000041691
www.hudsonmohawkinspections.com
Old 11/3/09, 9:41 AM
Cool Re: Cement poured against Hardi Siding
I can't remember EVER seeing a gap between the stoop and siding whether its fiberous, board and batt, stucco or even vinyl. The concrete is always poured up on the siding. Therefore by logic, the details MUST be wrong because as the builders or realtors always tell me: "It Passed Code".
There was another crazy detail in the link. It was something called a "Kickout Flashing". I've heard some crazy guys say you're supposed to use them with virtually all sidings: stucco, EIFS, vinyl, aluminum, fiberous, board and batt, masonry, etc. Again in the next 20 houses I might see them installed 2 times AND 1 of those times it would be wrong (too small, just a step flashing bent at an angle, etc). Therefore by logic, the details MUST be wrong because as the builders or realtors always tell me: "It Passed Code".
We gotta get better informed on this stuff AND quit making waves and upsetting people on this stuff that obviously PASSED CODE.
warped vinyl siding sgreen2 Exterior 4 10/28/09 7:36 AM
Fiber cement siding wwarner Exterior 10 8/19/08 4:27 PM
Recommend painting cement board siding mnicholet Exterior 1 8/7/08 5:13 PM
Composite Concrete siding Issues I need Help rkie Exterior 13 5/1/08 8:27 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
