How would you write this? The chimney is deteriorated and the cap is damaged. The flue liner should extend to the top of the chimney.
I think you just wrote it.....
Report what you see. That is all its about. What happens next is up to the client, not you. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
What Cap?
"I create controversy whether they like it or not" |
David,
You may or may not be aware of the MB SEARCH function on the control bar...also many rely on CSIA for report verbiage and referral suggestions...keep posting and you'll get your answer or Carl will show up hth ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
David,
What you said. |
Hey, get off the top of my house!!!!
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'd write it something like this...
Recommend repair by qualified contrator before close of escrow. |
Thanks for that CSIA link Barry, that was a good read today!
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 7:11 PM |
| Chemical Chimney cleaners do not work | rcooke | Canadian Inspectors | 5 | 2/12/08 1:02 AM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 9:16 PM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
