www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
Carl it does have some kind of support.
Is the flue liner supported properly? Probably not. I would believe the better question would be is why did they sleeve the existing chimney? I believe Joe Haggerty has an excellent comment on chimney inspections somewhere here on the board that reccomends all chimneys be evaluated by experts. |
Metal flues are supposed to have support if more than 4' above the roof.
In this case if it is 4' above the existing chimney I would think. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Thanks Brian,
I was wondering myself why the hell does the flue go so high. I was add a comment when there is a fire place that they should have a level 2 inspection of the chimney. I just cant work out why the hell it goes so high. The roof was a 5 crimp tin roof so I could walk it to get up near the chimney. www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
It did go more than 4 feet it was nearer 5 feet
Thanks Dale www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
It appears to have not met the basic 3-2-10 rule, which may be why they raised it with the metal flue.
In any event, besides the general level2 inspection recommendation, you should make mention of the modification to the original chimney and recommend obtaining permits, warranties and receipts for the work performed. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Maybe too much Viagra, sorry guys, couldn't resist.
I think Jeff's on to it. They didn't want to significantly prune the tree, so the took the flue higher.
Joe Hagarty's recommendation, I believe, is what most of us use. This is mine from my Interactive Report System: Quote:
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
| Chimney problems | mroe | Inspecting HVAC Systems | 13 | 3/30/06 10:14 PM |
