This chimney terminated about three feet from this opened skylight. I found several references to vents terminating near openable windows, but can't find anything about chimneys. I know it's wrong, but would like to have a reference.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The only reason I don't see it as a problem is the chimney and skylight would most likely not be used at the same time. Either it is too cold so you have a fire or it is too hot and you open the skylight. It will be interesting if anyone finds something on this installation. Maybe in the skylight installation instructions.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
I think it would fall under this.
Chimneys shall extend at least 2 feet higher than any portion of a building within 10 feet. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Stephen - That makes sense, but we can't rely on common sense now can we LOL!
Chris - It was at least 3 feet high, and 2 feet higher than anything within 10 feet. That part was OK. If fumes from a plumbing vent are considered dangerous, oil boiler exhaust must be too. Right????????? "A man cannot be truly grateful and remain unhappy"
[quote=bsmith;790471]Stephen - That makes sense, but we can't rely on common sense now can we LOL!
Isn't that the truth. Something along the lines of "Don't stick hand under running mower".... Whatever happened to survival of the fittest? Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Chimney clearance question | bgromicko | Inspecting HVAC Systems | 0 | 1/7/10 11:11 AM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| metal chimney clearance from trees | jweinberg | Exterior Inspections | 5 | 11/3/06 11:40 PM |
