Potential leak issue?
Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is there step flashing under the counterflashing?
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Can't tell (all caulked up). The shingle over the front is "tarred" in place and I couldn't see the apron flashing either.
I may be over-thinking it, but it's not what I'm use to seeing and can't make assumptions.
It looks to be a "sleeve" that was placed, after the chimney repairs were done. I have only seen this a couple of times, and both times it was the mason that installed it. One giveaway is the counter flashing. Did you inspect it from inside the attic?
Yes, I didn't notice anything unusual from the attic side.
I actually prefer the sleeves being in MN. When the snow and ice builds up around the chinmey, and autumn & spring hits with the freeze thaw cycles, there is less chance of moisture getting through any step flashing, and deteriorating the morter behind it. I know you've seen that problem over in WI.
Thanks for the help!
What happened to the industry? I really do not understand. I see so much of this type condition around chimney's and around dormer wall edge to roof.
Do installer's not know about the importance of flashing? There are so many water leak issue's in new homes as compared to the older homes that have, and you can see, the flashing. Sure sign of leaks when you see tar and or caulk. How do inspector's check for flashing under shingles or under siding? These roof's leak. May not be evident for a few years. They do leak. Talk about fishmouthing shingles, and or rotting roof sheathing. Defective workmanship. Keeping Inspector's busy. LOL |
Low bidder gets the job.
Is that simulated brick veneer or full brick on the chimney?
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Suspect: Faulty shingle installation.
Attachment 46873 Defective flashing: no step flashing. Recommend a licensed roofer do the needed repairs. Cost: $400 - $600 dollars. That would be in my area Canada. Because there is no step flashing the badly placed shingled seams at the corners of the chimney will have a higher probability of leakage.They may pull away from each other due to expansion and or contraction. Sizer's or step flashing go under each shingle and allow for expansion and contraction of the materials. It is apparent the is no step flashing. Attachment 46871 Counter flashing on top. It would be cut into the brick masonry bedding.on the upper and lower sides. Attachment 46872 For the 2 side plans the step flashing or the counter flashing may be cut in. The counter flashing would have a 3 to 4 inch lip on-top When the chimney expands it will open the butt seams in the shingles. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/5/11 at 10:36 PM.. |
Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
That chimney job 'Fails'. It'll only last as long as the caulk holds.
This may help. I see I need to add more pictures too. http://www.albertsroofing.com/Chimney%20Repair.htm |
Inspection yesterday. Roof in very good shape. Shingles on ridge, "erosion". Most of granules gone, corners curled. At chimney, observed the bad flashing. One piece of flashing on each side, brown caulk at top of brown metal trim to masonry. Little to no wind--I smelled mold!! I was able to put slight pressure downward and move shingles and sheathing down a little.
Went back inside, attic crawl. OSB black! Home 15 years old. |
YES! Potential leak.
Sidewall flashing should be step-flashing. Flashing on the downhill side should be out over the top of subsequent courses of flashing. Google "mastering roof inspection" and learn how to really inspect residential steep-slope roofs. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Chimney flashing | azuehlke | Exterior Inspections | 22 | 12/27/11 9:57 AM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Chimney flashing | sfalvey | Exterior Inspections | 1 | 10/5/07 8:12 AM |
| Question about chimney flashing | waksell | Exterior Inspections | 16 | 6/26/07 12:25 AM |
