Old 10/10/07, 1:12 AM
Default Chimney flashing photo's needed: brick and stone done correctly
For the Green Building Course I need a couple of good clear photos of brick and stone chimneys flashed correctly. Actually it's the counter-flashing method of attachment to the chimney that I want to show. Looking for photos rather than illustrations. Any photos used will be credited.
Please e-mail rather than post... peaktoprairie@msn.com
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/10/07, 12:11 PM
Carl A. Brown's Avatar
Default Re: Chimney flashing photo's needed: brick and stone done correctly
Kenton
This guy might be able to help you.
http://rooferscoffeeshop.com./
Old 10/10/07, 12:31 PM
http://www.masoncontractors.org/news...20070412094235
http://www.brickinfo.org/BIA/technotes/TN7.pdf
Old 10/10/07, 4:12 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
very helpful Carl. Thanks.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 10/10/07, 10:48 PM
Thanks guys, but I'm not looking for how to do it info, just photos from inspectors, especially for stone chimneys, which I almost never see flashed correctly.
(303) 717-8940
Old 10/12/07, 11:53 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not sure where to begin. I think I have a few close-ups of correct and wrong ones. I won't be back until Monday. Please feel free to browse my albums here. http://www.rooferscoffeeshop.com/pho..._list.asp?u=30
There are over 80 of my albums on this page, but the titles might be deceiving at times.
Look at my site to see if anything there can be or use to you.
http://www.albertsroofing.com/
E-mail any questions, or PM me. A friend from another forum mentioned this thread and hoped I could help. I hope it helps.
Old 10/13/07, 9:10 AM
I found this and don't know if it helps or not.
Roof Flashing | Chimney Flashing
Flashing is a construction detail used to seal and protects joints in a building from water penetration. The joints created by the intersection of the roof and roof mounted structures and projections, such as parapets, hatches, skylights, chimneys, vent stacks, or towers, are among the most vulnerable areas of roofing systems. They constantly expand and contract in response to changes in humidity and temperature. The greater the number of such projections, the greater the potential for serious leaks. Flashing is used at these intersections to keep rainwater from leaking into the building. It makes joints at these junctions watertight, while at the same time allowing the natural expansion and contraction of materials to continue. It operates on the principle that, in order to penetrate a joint, water must work itself upward against the force of gravity, or in the case of wind-driven rain, would have to follow a tortuous path during which the force of the wind would be dissipated.
nextlast
http://roofersreview.com/d/453-3/chi...816137d25ff9e6
Chimney flashing detail illustration / picture
Chimney flashing details. Shingles, step tins, apron flashing and counter flashing. Chimneys flashed in this manner are very rare.
http://roofersreview.com/d/503-3/Chi...816137d25ff9e6
Chimney Flashing Details Illustration
Chimney cricket flashing details. Apron flashing, step tins,cricket flashing and counter flashing.
http://roofersreview.com/d/500-3/cla...816137d25ff9e6
Clay tile and copper chimney flashing detail.
Copper chimney apron is set into a stucco faced wall and then pieced and soldered to fit clay roof tiles.
http://roofersreview.com/d/6201-2/Re...816137d25ff9e6
Rebuilt chimney on 150 yr old slate roof.
Old galvanized flashing on slate roof near Hudson, Ohio. The roof slates have lasted a long time with some repairs, but the chimney through the roof ridge has been replaced and re flashed.
http://roofersreview.com/d/6204-2/ch...816137d25ff9e6
Chimney / valley flashing on slate roof.
Slate roof galvanized metal valley flashing butts up against brick chimney. The roof slates, valley and chimney flashing are original and about 80 yrs old.
http://roofersreview.com/d/6207-2/sl...816137d25ff9e6
Chimney / valley flashing on slate roof 2.
Top corner of chimney flashing and bottom of roof valley . The valley flashing extends beyond the chimney to direct water away from the side flashings.
http://roofersreview.com/d/6210-2/Ga...816137d25ff9e6
Quality Roofing for Less | Chula Vista -Galvanized chimney / roof cricket.
Roof and flashing replacement. The old roofing has been replaced with dimensional style roof shingles. A roof / chimney cricket has been added to help remove water from behind the chimney.
http://roofersreview.com/d/6212-2/Pa...816137d25ff9e6
Absolute Roofing | Vancouver CA - Painted aluminum chimney flashing.
Absolute Roofing from Vancouver used a pre painted aluminum sheet metal for flashing this chimney.
http://roofersreview.com/d/6214-2/st...816137d25ff9e6
Stone chimney with tarred up copper flashing.
The copper sheet metal on this chimney has been lathered with tar and still leaks. The rear shed roof was likely the cause of the original leak.
http://roofersreview.com/d/6217-2/Sh...816137d25ff9e6
Shed roof chimney flashing.
Just a sloppy job of flashing a chimney on a modified bitumen roof.
http://roofersreview.com/d/6220-2/Fl...816137d25ff9e6
Flat tile roof chimney flashing.
A typical low budget chimney flashing job on a flat tile roof. The roof leak was probably caused by faulty roof / chimney flashing under the tile.
http://roofersreview.com/d/6226-2/Ho...816137d25ff9e6
Installing copper flashing on stone chimney.
How to install new copper flashing on a stone chimney and slate roof.
Owner: Roofers Review
http://roofersreview.com/d/6306-2/Br...816137d25ff9e6
Brick chimney with leaking flashing.
This roof is about eight years old and has developed a leak aroung the main chimney. The roofers went over the existing shingle roof and neglected to do anything about the chimney flashing. Except for smearing another layer of tar around the base.
http://roofersreview.com/d/6308-2/ch...816137d25ff9e6
Chimney restoration
A very nice restoration of a brick chimney in Chautaqua, NY
http://roofersreview.com/d/6311-2/co...816137d25ff9e6
Slate roof with copper flashing around chimney.
A one piece apron and saddle flashing. The one piece design makes it hard to conform the flashing to the old roofing. Notice how the lower roof slates are lifted by the flashing.
http://roofersreview.com/d/516-3/Sla...816137d25ff9e6
Slate Roof Terms
Professional slate roofers equipment. This is the kind of roofing equipment and materials / construction you should see a roofing contractor using when repairing your slate roof.
http://roofersreview.com/d/6687-2/re...816137d25ff9e6
Replacing chimney flashing
http://roofersreview.com/d/6693-2/Sa...816137d25ff9e6
Sandstone wall flashing.
Failing caulk on copper / sandstone wall flashing.
http://roofersreview.com/d/6696-2/Sa...816137d25ff9e6
Sandstone wall flashing - lead " reglet "
New lead " reglet " counterflashing cap over copper flashing on sandstone wall.
http://roofersreview.com/d/6734-3/Co...816137d25ff9e6
Copper valley dormer pocket 40
http://roofersreview.com/d/470-3/Cop...816137d25ff9e6
Copper step flashing on brick wall.
Brick wall next to spanish clay tile roof counter step flashed with copper.
http://roofersreview.com/d/3230-2/Ch...816137d25ff9e6
Chimney Step Flashing Leak
Finding the source of a roof leak next to a brick chimney. This chimney step flashing leak was found on a local college campus administration building. The damage from the leak is showing up on the outside of the building under the roof eave in a corner
http://roofersreview.com/d/497-3/Sla...816137d25ff9e6
Slate roof valley flashing repair.
Copper valley flashing replacement on Vermont mottled purple and green slate.
http://roofersreview.com/d/6821-2/Ch...816137d25ff9e6
Chimney flashing asphalt shi05
http://roofersreview.com/d/6824-2/Ch...816137d25ff9e6
Chimney flashing asphalt shi06
http://roofersreview.com/d/7229-2/Ba...816137d25ff9e6
Basic chimney flashing
Installing aluminum flashing on asphalt shingle roof with a brick chimney. The flashing will be fabricated from a sheet of .032 guage aluminum that has been pre finished front and back with bronze color paint. The shingles that were installed are GAF Timb
http://roofersreview.com/d/531-3/lea...816137d25ff9e6
Lead stack flashing.
A custom fabricated lead soil vent stack flashing installed on a steep slate roof near Cleveland, Ohio. Ready made lead flashings for steep roofs are not readily available at most roofing supply stores so this one was fabricated in the shop. The flashings
Old copper chimney step flashing.
An excellent way to install copper roof flashing on a brick chimney. This chimney flashing was installed over eighty years ago at the time the house was built and the roof installed.
Copper bow window roof flashing.
Angled, stepped counter flashing on a bow window with a standing seam copper roof. This bow window originally had a flat terne coated tin roof and was recently damaged by a falling tree. A decision was made by the homeowner to replace the old roofing wit
Chimney apron with reglet.
Copper chimney flashing apron installed with reglet set in mortar. The apron flashing, the copper piece that covers the slate at the bottom front face of the chimney, is held tight to the slate with copper tabs.
If anything, there is a good variety.
Hope this helps.
Marcel
Brick and stone Mortar deteriorating rjack1 General Inspection Discussion 5 4/11/07 12:50 PM
