Old 6/12/09, 11:50 AM
Rick Vollmer Rick Vollmer is offline
Please Note: Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Chimney Question
I just received an estimate of over $4,000.00 to reface a section of my brick chimney, as some of the brick facing is coming off. I was told to use a breathable water sealant at least every 5 years, as I also have water coming into my fireplace.
My question is, since I cannot afford to have this work done this summer or even next winter, is it o.k. to apply the sealer now. Will this help, hurt or not make a differance?
If I can apply, does anybody have a recommendations on a good sealer?
Many thanks in advance.
Find an InterNACHI certified Virginia Home Inspector (and anywhere else in North America)
Old 6/15/09, 7:30 AM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Chimney Question
Siloxane Sealer
Old 6/15/09, 11:52 AM
Joe Funderburk, CMI's Avatar
Do you have a rain cap/spark arrestor on the chimney?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/15/09, 1:00 PM
If there is any part of all of the bricks left (so that there are no holes completely through the chimney) the sealer may work for a short while, provided you also have a good rain cap over the opening. If it is really bad and you can't fix it now, I would recommend forgetting about using the fireplace until it is repaired. In that case, you can just put a piece of heavy plastic or tarp (tied securely) over the whole thing until you can get it fixed.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 6/21/09, 9:07 AM
Thanks for all the replies. There is a rain cap on the chimney. I had an roof tear off and new roof put on last Friday. They found that the leak was coming from rotten wood around the flashing. Somebody had put on a second layer of shingles and did a crappy job. No leaks since the new roof and flashing.
The brick problem I was told is basically cosmetic. I am going to apply some sealer this week, and have a new liner and insert installed before winter.
Once again, thanks to all.
Chimney Termination Requirement hspinnler Structural Inspections 17 12/5/10 6:14 PM
chimney crack rcantrell Exterior Inspections 7 4/4/06 8:10 PM
Chimney problems mroe Inspecting HVAC Systems 13 3/30/06 10:14 PM
