What type of material is this chimney. Home was built in 1952.
Is it the same material as asbestos cement. How would you report the chimney. Is transite the proper name for material? I did report on the imprope rpitch at the water tank. Need to identify chimney material. Thanks Dave |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
transite - yes
asbestos cement - yes although it might say "type B vent" on it, hairline cracks in them can go undetected and be a fire hazard. |
CC
Thank you for the reply. How would you report this condition to your client? Dave |
If not accessible to mechanical damage or cracked, transite doesn't pose a great hazard. It probably contains asbestos and I point that out in my report and suggest evaluation.
The biggest risk is that many jurisdictions don't allow replacing a furnace using this flue material and removal and disposal can be a significant cost. |
It appears to be a transite pipe however, that can only be verified by a lab. As for replacement, laws differ from state to state. In Illinois a homeowner in a single family dwelling can remove it and dispose of it in the garbage. However, if you're an asbestos abatement contractor or it is a multi-family unit, you have to be licensed and dispose of it properly.
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
It doesnt look like theres much slope for venting the unit
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 4:38 AM |
