Did an inspection the other day on a lakefront house with cinder block siding. Had cracks in the mortar (sealed). Mortar cracks in siding, did not appear to be structual issue? Any additional comments would be appreciated. Thanks
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
...when you say "sealed", are you saying 'with caulk or other sealant' or, 'properly repaired with mortar'??? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
In all your years of inspecting, have you ever seen this before? How did you report it?
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
I would call it Structural and Water Damaged.
Pic# 2 The crack at the ground radiates from a step down in the foundation/slab. Pic# 1 I see water getting in at window openings and exiting the foundation. What else did we find inside the house? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Sealant- silicone; grayish; not mortar; does not appear to be structural issue. no inside cracking or visual cracking; house in fair condition. Used as an condo in past
We can't say if it is an issue, but we can say it is structural.
And that it requires continued maintenance. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
monitor for any further issues
and fix the water intrusion exfiltrating at the foundation.
looking at the corner of the house its 8inch block, not siding. If thats the case then it's likely solid masonry making it a structural problem stemming from the crack in the foundation below.
Of course it is a structural issue! The wall was not built with silicone caulk was it? A mason needs to remove all "silicone caulking" and the wall repaired properly with mortar and whatever else is deemed necessary by the mason.
Most cracks are "structural". Some are significant, and some are not. Based on pic 2, I would have referred to an engineer. I see 2 horizontal cracks (1 of them very long filled with caulk). I see 3 diagional cracks. Something is going on. Solution could be as simple as as doing better water management (gutters, grading, etc.) 5 cracks in one area is too much for me to be comfortable with.
Those aren't cinder blocks BTW.
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 12/15/11 at 12:07 PM.. |
Your so darn picky!!
Lateral forces on the foundation at or below grade or horizontal uplift under the footprint or slab are most likely in my area. 6.5 foot frost zone.
Pour lot slope, clay will do the trick also. Can not see where you are from Mr. Young. Area code 601. Mississippi. Known as serpentine cracking in the CMU masonry bedding. Z shaped masonry bond cracking. The mortar was re-pointed or caulked. If it was caulked it is the wrong technique. The caulk will trap RH and excess moisture and further erode the masonry bedding and head joints. Can it be a structural issue, YES. JMO montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Vertical crack with leak in cinder block foundation wall | Peter Kozo | Structural Inspections | 10 | 8/3/11 10:35 PM |
| Cinder block support | rwashington | Structural Inspections | 9 | 5/18/08 4:18 PM |
| Cinder Block foundations | jlybolt | Structural Inspections | 32 | 11/14/07 7:05 AM |
| Step cracks in stucco on block home | dbucknavich | Structural Inspections | 1 | 5/19/06 7:53 PM |
| big cracks in block = small cracks in brick | mbryan | Structural Inspections | 5 | 2/21/06 10:40 PM |
