Old 10/30/08, 7:03 PM
jgattenby jgattenby is offline
Default Code for requirment of handrails
I need section ref in IBC 2003 that explains the need for handrails to stairs in excess of certain height. I am having a big brain cramp and can't find it.
All help would be great.
Thanks
Jeff
Old 10/30/08, 7:14 PM
David P. Valley's Avatar
Default Re: Code for requirment of handrails
IRC R311.5.6 Handrails
Handrails shall be provided on at least one side of each continuous run of treads or flight with four or more risers.
Old 11/1/08, 9:02 PM
Joe Funderburk, CMI's Avatar
A good illustration of the code requirements: click here
Whenever I cite a handrail, guardrail, etc. issue, I give them a link to this document on my website.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/1/08, 10:10 PM
Humberto Carvajal's Avatar
Humberto Carvajal Humberto Carvajal is offline
Very handy information to have readily available Joe. Thanks!
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED®
Accredited Professional
Member USGBC South Florida Chapter
Old 8/23/11, 8:59 PM
tgiles tgiles is offline
I need specifics on steps leading up to a concrete porch. What is the number of steps or height that requires them to have handrails? Steps and porch.
Old 8/23/11, 9:05 PM
Jeffrey R. Pope's Avatar
4 or more risers requires a handrail.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/23/11, 9:07 PM
R311.5.6 Handrails.
In snow and ice country safety is the concern in my recommendations, however.
Larry Kage, CMI
231 929 3525
Old 8/23/11, 9:56 PM
Thanks
Jeff
1009.10 Handrails
. Stairways shall have handrails on each side and shall comply with
Section 1012. Where glass is used to provide the handrail, the handrail shall also comply
with Section 2407.
More here;
IBC on Handrails and risers
Old 9/7/11, 10:17 PM
William J. Decker's Avatar
I run into many stairways with less than 6'8" headroom clearance (BTW: I am 6' 8". If I hit my head, it ain't up to code).
But, I would have to put this in 80% of my old house inspections, especially with basement stairways.
Do you actually call this out, knowing that nothing will be done and the client may freak out, it being a code issue?
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 9/7/11, 10:47 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
My thought exactly. I would recommend for safety reasons that a handrail should be installed or the oh so common issue with balusters.. But for height on a landing or stairwell itself, I would not.
Old 9/7/11, 11:04 PM
My question, specifically, was addressed to the 6' 8" height reauirement for headroom.
Will Decker, CMI
Old 9/7/11, 11:12 PM
Bob Elliott's Avatar
Might as well call out the illegal Unit while you are down there.LOL
Everything depends on the local area and what is common practice.
I often explain things will be in the report (CYA) .......buuuut.
Old 9/8/11, 6:10 PM
Without measuring, Will would be the only one to notice.
I never measure it unless it is a new build.
Plus like Will said, they would not do anything about it anyways.
I would only note it if lower than 6'4 or less. On the average, 6' seems to be the norm. Will, Hope you stopped growing.
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/10/11, 3:01 PM
Mark S. Tyson Mark S. Tyson is offline
Will,
Most folks wrongly apply section 311 of the I.B.C. to basement stairs. 311 governs means of egress while basement stairs are required to comply with section 310, and 311.5.8.2 of the I.B.C. which exempts basement stairs from the head room requirement, landings, stair tread depth, riser height, etc. Providing that the basement floor is not more than 8 feet below adjacent grade and that the stair is not one of the buildings required egress openings. So basically unless the home does not have any exterior doors and the basement is not more than 8 feet deep no need to report
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 9/10/11, 3:10 PM
To clarify my earlier post the code articles cited are from the International Residential Code and not the I.B.C.
Mark S. Tyson
Member N.A.C.H.I.
IAC2 certified
Garage/house fire door Steven C. Meyer General Inspection Discussion 15 2/5/08 8:06 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
