Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 9/18/08 at 8:43 PM.. |
Hey that is not EIFS it is just some 2x4's
Those walls will leak if you leave them like they are! I can not wait to see the info. But I will. "I create controversy whether they like it or not" |
Carl, I added some sheathing for you and took a second PIC: http://www.nachi.org/eifscoursecomingsoon.htm
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 9/18/08 at 8:38 PM.. |
Thank you!
What is next? "I create controversy whether they like it or not" |
Are they spacing the sheathing as per mfgrs. specs?
For some reason framing hurt a lot more than I remember. I used to be a fairly fast framer. Now I'm a fairly sore ex-framer!
Specs? Specs? Send in the punch crew! We have a crew from a very successful and knowledgeable contractor coming in to put a variety of stucco/EIFS coatings on these panels and highly-qualified instructor who will show inspectors how to identify the various systems and spot defects common to each. This video will also will include proper flashing methods at openings and terminations. This will be a good one. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Kenton,
Can you post a good picture of what is printed on the OSB? I am sure you are sore, I can only imagine picking up a hawk and trowel after a year and a half. "I create controversy whether they like it or not" |
We can do that Carl. Do you have any photos of defective conditons that have resulted from failure to allow for panel expansion?
It's been about 7 years since I've framed after about 30 years of it. That's real time. Feels like about 17 years in lower back time. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Not that can be verified.
Imagine if you will a comp roof that has no spacing of the sheathing. The kind where one can count the sheets of OSB.
Now imagine a wall where the sheathing has no spacing. By the time the stucco is torn off the OSB is a pile of moldy mulch. "I create controversy whether they like it or not" |
Any new pictures?
I was in the trades when OSB first appeared. At first, many of us jammed the sheets tight together, so I know many structures have been built that way, wrong as it was. I know there've been many roofs sheathed with OSB without proper spacing and covered with comp, but I don't think I've ever seen one in which I could count the OSB sheets through comp shingles. I'm sure many walls have been sheathed with OSB without spacing too, but I don't remember seeing any problem in walls which were covered with a membrane and a properly-flashed exterior wall covering. My understanding is that for that OSB sheathing to turn into moldy mulch, a severe moisture intrusion problem of the sheathing must be present. Moldy mulch would be related to the actions of decay fungi resulting from moisture intrusion and unless the intrusion were caused by bowing (which will not ocurr without moisture intrusion), decay would have more to do with the stucco application than the sheathing application. Is this not right? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Hot PIC of Professional Engineer and InterNACHI member Ron Hoffman reviewing development of new EIFS inspection course:
http://www.nachi.org/eifscoursecomingsoon.htm Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
Hurry up the people want to move in and they do not care that the weather has not been helpful. "I create controversy whether they like it or not" |
Kenton,
Keeping it dry is a real problem for some. http://badstucco.com/improperprep/IMPROPERPREP.html "I create controversy whether they like it or not" |
| 714 mile inspection, I've gone farther and worked longer | badair | Structural Inspections | 9 | 7/7/08 5:44 PM |
| Infrared Training Coming To Dallas & Denver | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 2 | 1/23/08 12:22 AM |
| Infrared Training Coming To Dallas & Denver | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/22/08 8:44 PM |
| Coming soon. Another free online comprehensive cours: Inspecting Green Buildings. | gromicko | Miscellaneous Discussion for Inspectors | 9 | 11/10/07 5:09 PM |
