scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
How would you write up concrete that was poured up to the siding. Basically the siding guys got there first and the concrete guys poured the porch against the siding. I'm looking for some good verbiage, and the potential problems.
Thanks, Steve |
Steve,
What type of siding was it? Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Vinyl
Here are some pictures.
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
If the concrete porch deck is not connected to the building/siding and can be replaced whilst doing nothing to the concrete porch, then the builder's did the wise and noble thing and you should write-up nothing.
Otherwise, section R703.8 FLASHING of the 2006 International Residential Code requires that the porch/wall attachement be flashed to prevent water infiltration. |
Don't know how anyone could condone this type of installation. Betwee the frost action and water intrusion, who knows what will happen. That concrete slab should be under the siding by at least 6-8" in my opinion. The house is set too low on the property for this to happen without causing a negative grade. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Not sure what I'm looking at; that could be anything from a balcony interface with the wall several floors up on a condo and partially protected by the balcony above to a patio slab at grade behind a single family home.
Wherever it is, not right. But how wrong it is depends on where it is. For example, if that was a patio slab, poured up to the siding on the rear wall of the house (something I see from time to time in my area) it's IMO a big problem: _____________________________________ Observation: At [location] concrete flatwork has been poured up to the vinyl siding and the bottom course of siding is embedded in the concrete. Analysis: The lower edge of the siding should be separated from grade. For vinyl siding a separation of 6-8” is typically recommended. When the lower edge of the siding is below grade moisture can be wicked up behind the siding and insects and vermin can enter the building unobserved. Either can cause severe damage to building materials behind the siding. This damage can extend a considerable distance above grade and/or into the building, and can become extensive before it is discovered. It is possible that such damage will be discovered when the siding is removed. Repair or replacement of the portions of concrete flat-work and/or the foundation wall adjacent to and/or behind the siding may also be required. Repair of this defect could be a substantial expense. Recommendation: Have a licensed and insured contractor relocate the siding to proved a minimum of 6” separation from grade, and perform any associated repairs as required. |
Pouring concrete up onto siding is neither wise nor noble. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I don't like this mortar application either, but what do you expect the homeowners to do now? Tear it out? I think not.
Make it simple...Write up what you see and don't lose sleep over shoddy workmanship. |
At a minimum, I want my client to understand that there is the potential for *very* expensive damage behind that wall. And I'd sleep fine if that knowledge caused a client to walk away from a house, for starters that situation is a prescription for creating *massive*termite infestation before damage is discovered. Last edited by mthomas2; 9/3/07 at 3:41 PM.. |
Just repositioning the siding will not solve anything, the sheathing and framing will still be in contact with the concrete, that slab needs to be ripped up and a new one poured lower or not at all, it doen't even need further evaluation, I would recommend what I said above by a qualified contractor, and call it out as a major expense.
Well you know that the framing and sheathing stopped at floor level, so it is highly improbable that they would extend the siding down the foundation wall 12". I am judging according to standard building practices.
| Moisture in slabs | mcyr | Structural Inspections | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural Inspections | 1 | 8/19/07 11:26 PM |
| Moisture control for slab on grade in protecting floor finishes | mcyr | General Inspection Discussion | 2 | 8/13/07 8:53 PM |
