Old 3/29/07, 1:16 AM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default concrete roof tile over asphalt shingles
Someone asked me a question today if it was ok to install concrete tile over asphalt. I told him no because concrete tile weighs about the same as 3 layers of asphalt shingles and he believes the house he is looking at already has 2 layers of asphalt shingle. In addition to making sure the truss/rafters (not sure, haven't inspected it yet) are in good shape as is the plywood/osb sheathing, is there anything else to lookout for in a possible conversion from asphalt to concrete....structually speaking. thanks
Old 3/29/07, 7:32 AM
wsiegel wsiegel is online now
Default Re: concrete roof tile over asphalt shingles
Normally when a concrete tile is installed, and the roof previously had shingles, an engineer is supposed to provide proof that the roof is able to handle the load. That is part of the permit process down here in Floirda.
Comp shingles over wood shingles Matthew Hopkins Exterior Inspections 28 10/16/07 12:19 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
