Old 5/24/10, 2:34 PM
Alan R. Glabe Alan R. Glabe is offline
Default Concrete tile installation
I recently inspected a house in Stockton, CA. The house was approximately 20 -25 years old and had the original concrete tile roofing in place. When I inspected the attic I noticed that the concrete tiles had been installed on skip sheathing with no underlayment used....just like a wood shingle roof would be installed. Is this OK?
Alan Glabe
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/24/10, 3:00 PM
Default Re: Concrete tile installation
A waterproof primary water barrier is, typically, installed first under concrete/clay tiles.
Larry Kage, CMI
231 929 3525
Old 5/24/10, 3:03 PM
Tim Spargo's Avatar
Alan,
When you say underlayment.. I assume you mean felt paper or similar. I've stepped thru the concrete tiles when there is skip sheathing under it, hope you didn't.
Anyway, if I looked at a concrete tile roof with no felt or building paper under it, I would certainly recommend in my report to have a roofing contractor evaluate.
http://www.nrca.net/consumer/types/tile.aspx#underlay
You can find a handful of resources out there.
Basically, a concrete tile sheds water, but the underlayment provides the actual moisture barrier. As a matter of fact, I let my clients know that I can not see the underlayment/moisture barrier (most are not skip sheathed) while performing a roof inspection.
If this not what you meant, the address I gave you should provide some info
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 5/25/10, 12:13 AM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Alan, I started my inspection business in the bay area and I found several homes built in the mid 1970's that had tile roofs over skip sheathing and no felt paper. I always made the client aware that it was typical for this age of home and that the roofs should be inspected annually.
www.MauiHomeInspections.com
Old 5/25/10, 12:36 AM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
As Mark said all is ok. During that time tile roofs were installed with no underlayment. There are pockets of homes around here like that. Tell them to have it inspected on a regular basis.
Chuck
Old 5/25/10, 10:07 AM
Thanks guys.....much appreciated.
Old 5/28/10, 8:34 PM
Tim Spargo's Avatar
I dunno if I'd say it was OK.... It's one thing to say "It was considered acceptable at the time it was constructed, but is no longer compliant by today's standards"
Giving advice on something that in a lot of regards is substandard and regarding it as OK is not something I really agree with. Weren't shake roofs OK at one time or another as well?
I wouldn't have "blessed" it
Tim Spargo
661-317-5770
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
