cwhite2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone know of a website explaining the correct way copper should be added to existing shingles on a roof?
TIA, |
Copper works better than zinc, but zinc is less expensive.
Carolyn,
They always get installed under the ridge shingles as it is the highest portion of the roof. I recommend these Zinc strips to my clients. Yes, Copper will work also. |
Hi to all,
just to add to the confusion I hope this helps (but suspect it doesn't) Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
OK - I realize I should've given a little more info on why I ask this question. I went with a friend to look at a house she was thinking of buying. I wasn't doing an inspection, she just wanted me to ride along to see 3 homes she is considering. I didn't have a camera with me & one of the homes had an approximately 6" wide strip of copper nailed about 1 1/2' down from the ridge of the roof. It was kind of woven between the lower edges of the row of shingles above the copper & the nails were driven through & exposed to the exterior.
Well, my friends fiance supposedly worked with a roofer at one point & time & he told her this is how they do it on an existing shingle roof & there is nothing wrong with it. I don't intend to get in the middle, but I told her I would expect the exposed nailheads to leak somewhere down the line, if they are not already. I wanted to find a website which showed (very simply) how to properly install it to show my friend. |
Exposed nails do not have to be removed. Simply recommend a dab of roofing tar onto all roofing nail heads. |
I love this site Carol, always has good info:
http://www.askthebuilder.com/B374_In...Shingles.shtml Here is a list of the roofing issues he's discussed. http://www.askthebuilder.com/Roofing.shtml Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Thank you Peter - That's what I was looking for.
Thank you to everyone else too. |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
