I ran across this today and I'm scratching my head. It was terribly hot and humid and the attic was miserable. I didn't stay up there for long but I put my hand between the roof decking and the ridge vent and there was no gap at all. On the roof side, there is corrugated plastic material under the ridge shingles but I don't see how the air can exit the attic without any gaps.
Now there were gaps present between the siding and soffit leaving the OSB sheathing exposed to the elements. What is it that I'm missing? The home was built in 2001. Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It vents through the corrugated plastic, I have this on my house. It's designed to prevent outside weather infiltration.
http://roofing.owenscorning.com/docs...erigidroll.pdf http://roofing.owenscorning.com/home...igid-roll.aspx Of course the siding is missing the J-channel, but you new that. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Looking at the link from the mfg it makes sense. But there wasn't any fiber between the roof and the corrugated plastic as shown in the link you sent to me. So tell me how the air gets from the attic through the plastic? Maybe the installer forgot something.....
It looks like it might be installed upside down. It's a one piece design, the fiber (film) is glued to underside. It comes flat and you fold it over the ridge. May be why it looks so wavy on the exterior side. Probably the same guy that installed the siding.
That could very well be what happened. I couldn't see under the ridge shingles but the good news is if they ever leak, the water will have a place to run onto the roof rather than in the attic
Sounds like the realtors around here. Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
I have never inspected a new home where I did not find at least one major problem, usually faulty or improperly installed electrical components.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
| High Temp Plastic Vent (HTPV) Pipes Recalled | jbushart | Inspecting HVAC Systems | 5 | 4/2/09 10:10 PM |
| Gas changes for plastic vents in Canada | rcooke | Canadian Inspectors | 0 | 7/30/07 2:15 PM |
| Hart & Cooley plastic furnace vent | apfaff | Inspecting HVAC Systems | 2 | 8/15/06 3:20 AM |
